Joined: 06/02/2018(UTC) Posts: 418 Location: Ontario, Toronto
Anyone knows if it can be run on R1 curves?
No ESU recommended R2 curve. At least 425 mm. |
H0 DCC = Digital Command Control
Joined: 21/10/2004(UTC) Posts: 31,696 Location: United Kingdom
I check ESU website and E94 do min radius is 360mm.  |
You have been a member since:: 16/02/2004(UTC) Posts: 15,452 Location: DE-NW
Minimum radius for ESU's BR 94 (a steamer) is 420 mm, according to their site. Sometimes models can handle smaller radii than specified by the manufacturer. |
Joined: 01/02/2004(UTC) Posts: 7,459 Location: Scotland
WE appear to have 360, 420 and 425. Take your pick.. I would go with what the site says. |
Take care I like Marklin and will defend the worlds greatest model rail manufacturer. |
 1 user liked this useful post by H0
Joined: 21/05/2004(UTC) Posts: 1,769 Location: Brisbane, Queensland
Originally Posted by: David Dewar  WE appear to have 360, 420 and 425. Take your pick.. I would go with what the site says. Just some confusion since ESU produce an BR E94 and also the BR94, which have different min radius. Since OP does not mention the E, Tom's answer is correct of 420mm. As he also says, OP should have just checked on the ESU website. |
modelling era IIIa (1951-1955) Germany |
Thanks. I saw the website before posting but wonder if anyone has success running the loco at R1.
No one has tried running ESU BR 94 on R1?
Joined: 01/03/2008(UTC) Posts: 2,883 Location: South Western France
Originally Posted by: QQQ1970  No one has tried running ESU BR 94 on R1? i tried to push a big round peg in a tiny square hole. Did not work.. I still wonder why? |
Jacques Vuye aka Dr.Eisenbahn Once a vandal, learned to be better and had great success! |
 2 users liked this useful post by jvuye
Joined: 15/12/2015(UTC) Posts: 523 Location: Maryland, Baltimore
FWIW, I bought the Brawa BR 94 because it stated the minimum radius as 360mm. It derails on R1. I contacted Brawa and they recommended it be returned to them to check the specs. I decided to and just live with it. Good luck!
Joined: 22/01/2009(UTC) Posts: 14,875 Location: On 1965 Märklin Boulevard just around from Roco Square
Originally Posted by: jvuye  Originally Posted by: QQQ1970  No one has tried running ESU BR 94 on R1? i tried to push a big round peg in a tiny square hole. Did not work.. I still wonder why? Jacque, there is a tool now available getting a square bit of timber rod and form it into a round dowel. John |
 1 user liked this useful post by river6109
I did checked ESU BR 94 in the youtube and it drives bad on the K double turnouts. Sometimes it´s short circuit. |
Joined: 14/03/2005(UTC) Posts: 15,871 Location: Gibraltar, Europe
I'm not sure why we are still discussing this? We agreed that the minimum radius for this loco is 420mm, so R1 curves and turnouts are off limits! |
Mostly Marklin.Selection of different eras and European railways Small C track layout, control by MS2, 100+ trains but run 4-5 at a time.
Originally Posted by: RayF  We agreed that the minimum radius for this loco is 420mm, so R1 curves and turnouts are off limits! The documented minimum radius for Märklin's French 241 loco is 420 mm, still it runs through 360 mm curves according to reports made here. I have Piko coaches with a documented minimum radius of 500+ mm with installed footsteps, yet I found mine can run through 360 mm curves. It is worth trying rolling stock on smaller radii than documented. The ESU PDF writes guaranteed minimum radius - this sounds as if smaller radii are possible. |
Originally Posted by: QQQ1970  Anyone knows if it can be run on R1 curves? Buy a Märklin BR E 94. I got a Märklin 39226 BR E 94 217 in white from the Infodays. This ones runs perfectly through my 360 mm R 1 curves.
 1 user liked this useful post by TEEWolf
Originally Posted by: TEEWolf  Buy a Märklin BR E 94. I got a Märklin 39226 BR E 94 217 in white from the Infodays. This ones runs perfectly through my 360 mm R 1 curves. That one doesn't have a smoke generator. This thread is about an "E-Lok", not about an "Ellok" (a distinction made by WeWaW in an old issue of MIBA). |
Originally Posted by: H0  Originally Posted by: TEEWolf  Buy a Märklin BR E 94. I got a Märklin 39226 BR E 94 217 in white from the Infodays. This ones runs perfectly through my 360 mm R 1 curves. That one doesn't have a smoke generator. This thread is about an "E-Lok", not about an "Ellok" (a distinction made by WeWaW in an old issue of MIBA). Thanks. You are right. I was mislead by the number again. Märklins is writing from a BR 94.5. Anyway it always makes its way on R 1 too.
Does the ESU factory digital coupler (much like telex) work with Marklin relex, close and current conducting coupler?
Joined: 08/05/2015(UTC) Posts: 576 Location: Tunbridge Wells, Kent, United Kingdom
I asked the question of MSL, as I was very interested in getting one of these models. Unfortunately they are not compatible ☹️
Also, a little off topic, the Brawa BR 94 says it will work with R1 cures, but it doesn't. Don't ask me how I know.
