Offline davo_vespa
#1 Posted : 14 November 2018 02:32:15(UTC)
davo_vespa
I've got a Roco Ludmilla circa 2005 (69913) which is as dead as a doornail on my Märklin analogue system (6647 transformers). Märklin loks (analogue & digital) work fine.
I know for some Märklin digital I need to set the switches to off but have no experience with Roco. Am I missing something obvious here or is it just buggered?
Thanks for your help,
David
#2 Posted : 14 November 2018 03:39:44(UTC)
David, it could depend on which decoder is installed in the Roco loco. whether or not one has to program the decoder I'm not sure. ESU decoders automatically recognizes the system you're running., for the decoder to work it should have a multi protocol system., if you have more information about the decoder it would help, did you buy it new or used ?
Offline davo_vespa
#3 Posted : 14 November 2018 03:55:09(UTC)
davo_vespa
Thanks John,
Picked it up second hand. The decoder would appear to be a Roco Motorola 10738....does that help?
https://www.roco.cc/en/p...0-004002-1/products.html
Sorry, way out of my depth when it comes to these things....I'm just a simple analogue man!!
Happy Days, David
Offline MaerklinLife
#4 Posted : 14 November 2018 05:19:56(UTC)
MaerklinLife
Analogue is probably turned off in the decoder. Off to a friend (or dealer) with a DCC layout and have it turned on again. Also try and reset the decoder to the factory settings.
Online H0
#5 Posted : 14 November 2018 08:12:01(UTC)
Not really. Roco used this ref. number for several different decoders, AFAIK including Lenz and ESU.
Are you sure the loco still has the factory-installed decoder?
A photo of the decoder might help.
Offline TEEWolf
#6 Posted : 15 November 2018 00:53:42(UTC)
David
Try a look here
https://www.roco.cc/en/s...digitalmodule/index.html
There is a manual for a lokdecoder AC 10738 listed.
https://www.roco.cc/uplo...nts/pdf/10738_V_2007.pdf
Online H0
#7 Posted : 15 November 2018 07:58:36(UTC)
Several different versions of the 10738 have been sold over time, each version came with an incomplete decoder-specific manual. Linking to one version of the 10738 manual that may not even correspond to the decoder in the Ludmilla is of limited use.
Offline TEEWolf
#8 Posted : 15 November 2018 23:49:57(UTC)
Did not know that Roco is doing such a shoddy quality. Laugh
But I prefer Märklin anyway. Love
This is the reason why I post at marklin-users.net - a Märklin and not a Roco community.Cool
#9 Posted : 16 November 2018 01:56:35(UTC)
What do you mean ? shoddy quality ?
Online H0
#10 Posted : 16 November 2018 07:07:57(UTC)
A crippled version of Roco 10738 was used for several Märklin locos like BR 120.0 or Sybic a few years ago. Basically Roco 10738 without DCC.
Some Märklin locos came with three different decoders over time (FX with DIP switches, programmable FX, mfx) - and the manual available for download only covers the latest decoder.
Märklin is the market leader and with respect to shoddy quality they beat Roco anytime...
What is shoddy about Roco in this case?
Offline TEEWolf
#11 Posted : 17 November 2018 01:18:19(UTC)
@H0 was writing in post #10
"Several different versions of the 10738 have been sold over time, each version came with an incomplete decoder-specific manual."
How would you name this insufficient and/or bad work of documentation in English?
Online H0
#12 Posted : 17 November 2018 10:46:25(UTC)
Märklinesque? LOL
Offline davo_vespa
#13 Posted : 18 November 2018 02:31:23(UTC)
davo_vespa
Hi All
Thanks for your input.
I was hoping an AC Roco would be a simple "plug & play" product but it would appear to be somewhat more complex....
As such, I have returned the lok and will stick with Märklin in the future.
Happy Days, David
thanks 1 user liked this useful post by davo_vespa
Online H0
#14 Posted : 18 November 2018 10:50:21(UTC)
Out of the box with the factory settings Roco AC locos work on analogue layouts.
When an old second-hand item does not work then this could be due to a defective decoder or the result of changed settings in the decoder or maybe even a replaced decoder.
Same goes for Märklin. I've had Märklin locos where the decoder was defective - analogue operation was still possible, but digital did not work.
#15 Posted : 18 November 2018 14:00:55(UTC)
David, it is easy to plug and play, its like buying a car but you don't have the key to start the car. digital decoders have certain settings for DC, DCC, Analog and Motorola systems and most of them recognize the system you're operating under., as mentioned before if it is a new decoder. next time you buy a loco make sure the settings are for analogue locos.
#16 Posted : 19 November 2018 22:45:17(UTC)
I have seen this happen with a Delta decoder that had the solder jumpers for address selection. It worked fine on analogue, but not on digital. The problem was the solder jumper had a dry joint. Redoing the jumper restored digital operation.
This page was generated in 0.599 seconds.
