Offline jorwes
#1 Posted : 12 November 2018 20:42:51(UTC)
jorwes
HI, a question.
I have no succeeded to add the first S88 to my CS2 and make it work. So now that one is full with feedback rails 1-16.
Now i will add one more S88 and then I use the RJ45 cable that is in the box.
So then questions.
1) will I have to connect the next S88 with ground connection as well or is that "inherited" true the RJ45 cable from the first S88 that has a ground cable to the rail?
2) will the 1-16 connections on my S88 no 2 end up as 17-32 on my CS2?
Best Regards
Jorgen W from Sweden
Offline Ross
#2 Posted : 13 November 2018 00:59:36(UTC)
Ross
Hi Jorgen,
You only require 1 gnd connection to the "T" on one of the s88's usually the first one.
For question 2 the answer is yes to 17-32.
Originally Posted by: jorwes Go to Quoted Post
HI, a question.
So then questions.
Best Regards
Ross
#3 Posted : 14 November 2018 00:13:18(UTC)
I assume you meant to write "I have now succeeded to add..."
Offline MaerklinLife
#4 Posted : 14 November 2018 16:28:55(UTC)
MaerklinLife
Delete, nevermind :-)
Offline Martin T
#5 Posted : 17 November 2018 14:44:15(UTC)
Martin T
SOLVED
Regards / Martin T
This page was generated in 0.282 seconds.
