Joined: 02/09/2014(UTC) Posts: 7 Location: STOCKHOLMS LAN, STOCKHOLM
HI, a question.
I have no succeeded to add the first S88 to my CS2 and make it work. So now that one is full with feedback rails 1-16.
Now i will add one more S88 and then I use the RJ45 cable that is in the box.
So then questions.
1) will I have to connect the next S88 with ground connection as well or is that "inherited" true the RJ45 cable from the first S88 that has a ground cable to the rail?
2) will the 1-16 connections on my S88 no 2 end up as 17-32 on my CS2?
Best Regards
Jorgen W from Sweden
Joined: 25/09/2006(UTC) Posts: 945 Location: Sydney, NSW
Hi Jorgen, You only require 1 gnd connection to the "T" on one of the s88's usually the first one. For question 2 the answer is yes to 17-32. Originally Posted by: jorwes  HI, a question.
So then questions.
Best Regards
Jorgen W from Sweden |
Ross
 1 user liked this useful post by Ross
Joined: 15/10/2006(UTC) Posts: 2,319 Location: Washington, Pacific Northwest
I assume you meant to write "I have no w succeeded to add..." |
Joined: 02/01/2006(UTC) Posts: 878 Location: Stockholm, Sweden
