Offline charles Sharpe
#1 Posted : 11 November 2018 12:26:33(UTC)
charles Sharpe
Hello All
Please can any body tell me if I can use the new s88 as a straight replacement for the old one or do I have to do some extra wire etc. I am running a CS 2 60215.
CHARLES SHARPE
#2 Posted : 11 November 2018 21:09:44(UTC)
The CS2 has a flat 6 pin connector for S88s.
- normally , for a S88 (6088,60880) a flat ribbon cable (e.g. 6089) would plug between the two
- for 60881(S88-AC) and 60882(S88-DC) an adapter cable (60884) is needed to convert from the 6-pin of the CS2 to the RJ45 connector of the newer S88.
Noting that you may intermix the two types of S88 module in the same chain as long as
- all the flat connector S88s (6088/60880) are first,
- then the 60884 adapter cable
- then the newer S88s (60881/60882)
The alternate solution is to invest in a 60883 (S88Link aka L88) which plugs into the CS2s (7-pin) booster port or a spare Terminal (60125/60145) port.
As well as providing a base 16 sensor ports, the L88 has sockets for both old and new connector types HOWEVER it does require its own power supply (6636x)
60884
This page was generated in 0.187 seconds.
