Offline Leitner
#1 Posted : 28 October 2018 16:18:36(UTC)
Leitner
Taiwan, Province Of China
Today the F7 complex of my Super Chief (26496) decided to stop working, basically while the locomotive was running I heard a weird noise and the locomotive pretty much stopped. I checked and apparently the wheels connected to the front engine (the locomotive has two engine) are stuck and there's no way to move them, the engine is working but the wheels gears are not moving at all.
Anybody has a suggestion on how to fix this?
santa fe.png (3,519kb) downloaded 49 time(s).
Thanks.
#2 Posted : 28 October 2018 18:13:11(UTC)
That’s strange. I own many sturdy M* F7s, but none ever stalled like that. Is there only one decoder driving both motors? If so, then you are facing a mechanical problem. The affected truck (or bogie) should have four rubber traction tyres. Are they are still in place? If not, maybe one got caught in the cog wheels.
Offline Leitner
#3 Posted : 29 October 2018 01:18:38(UTC)
Leitner
I owe an update, I tried to clean the gears from "outside" but I couldn't manage to solve much, then after a hour of waiting it started to work again just fine. It's the first time I experience such a thing with a Marklin locomotive; it's quite weird.
thanks 1 user liked this useful post by Leitner
#4 Posted : 29 October 2018 09:24:50(UTC)
Probably caught some ballast+or other particle between the teeth of the gear.
Happens from time to time...Wink
This page was generated in 0.393 seconds.
