#1 Posted : 23 October 2018 12:33:53(UTC)
I did connect m83 to the CS3 and Rocos semaphore to the m83.
When i switch off the CS3 and turn on again the semaphore change automatic while the symbol in the screen CS3 stand vice verse.
It happens every time.
Why?
Both m83 and m84 was connecting together and only m84 was feeding the wires from the CS3.
I did tested alone m83 too but same problem anyway about semaphore changed.
Second problem are LED standing position in the m83.
It doesn´t lighting just only when i change switch.
#2 Posted : 23 October 2018 21:54:53(UTC)
Have you looked in the technical manual, and set the correct parameters / CVs for pulse width etc. for the m83 ??
Try with just a multimeter, bulb or LED on the output of the m83, so you can see what happens.
#3 Posted : 23 October 2018 22:57:30(UTC)
mfx m83 are set standard by of Märklin.
#4 Posted : 23 October 2018 23:20:14(UTC)
How should Märklin know if you are using C-track, K-track or M-track; Normal turnouts, 3-way turnouts or double slip switches?
In your case you are using a ROCO semaphore, and you think the CVs for your semaphore is set as standard by Märklin ???
I'm trying to help you; but you just don't want to be helped.
#5 Posted : 24 October 2018 06:59:58(UTC)
Rocos semaphore has magnet motor are same like Märklins turnout motor.
You need only switch about 200 ms.
The mfx m83 are set this as standard by of Märklin.
#6 Posted : 24 October 2018 09:34:15(UTC)
Is this not the answer to your second question??
Second problem are LED standing position in the m83. It doesn´t lighting just only when i change switch.
#7 Posted : 24 October 2018 12:35:22(UTC)
If you did read the first post i did wrote that semaphore switched automatic when i switch the power on again with the CS3.
The screen shows semaphore still red while the semaphore switch over to green byself.
If the screen stand green the semaphore switch over to red.
This happens everytime when i switch the power on the CS3.
#8 Posted : 24 October 2018 13:07:13(UTC)
Yes, I read that part, and that was the first question, to which I have no answer yet.
Have you tested the output of the m83 as I suggested, to find out if it is the CS3 / m83 or the ROCO semaphore making the problem ??
If the semaphore works as a stepping relay / uniselector; then this could happen; but I don't know how ROCO semaphores work,
and you haven't even told us which model you are using.
Your second question/problem was regarding the red/green light on the m83, which I believe we have found the answer for.
Did you read you own post Confused
#9 Posted : 24 October 2018 15:04:23(UTC)
Does this just happen with a Roco signal and not Marklin signals.
#10 Posted : 24 October 2018 16:40:07(UTC)
We don't know, and Goofy doesn't want to test the output of the m83 and tell us the result.
Apparently all 40 - 50 CVs in the m83 is set for ROCO semaphores as a standard from Märklin, which sounds really strange to me.
I also find it hard to believe that lights in the semaphore should stay on, with only 200ms signal from the m83;
but can't find any manuals to the ROCO semaphores, and I don't know which one he is using.
#11 Posted : 24 October 2018 17:38:55(UTC)
I had previously thought Roco made good quality stuff. Now this.
Goofy may have to switch brands again.
#12 Posted : 24 October 2018 17:52:44(UTC)
Why?
This behaviour is normal when you connect the "green" input of the signal to the "red" output of the m83 and vice versa.
Maybe the wiring is correct, but some CVs have inappropriate values.
#13 Posted : 25 October 2018 18:36:49(UTC)
Goofy, please tell us if you found a solution to your problem.
#14 Posted : 27 October 2018 07:27:45(UTC)
Why?
The wires are connect right.
It works as normal too.
The problem are when switch on the power back to the CS3 it happens that semaphore changes vice versa automatic.
This happens everytime when i switch on the power to the CS3.
I did checked m83 status too via configuration and it stand normal.
I gave up and did return things back.
I try another way and this time with an Lenz LS150.
Offline siroljuk
#15 Posted : 27 October 2018 09:12:57(UTC)
siroljuk
HelloBigGrin
I have noticed that if you leave testing-button active in CS3Plus after testing, example loco-sounds, that sound which testing-button remains active in setup will be heard every time when that loco is on the track and track-power comes on. For example pushing stop-bar off-on.
Sorry for my poor English languageBlushing Blushing but you should check that all is ok in your Roco semaphore setup, perhaps you have forgot something on in semaphores setup.
Jukka
#16 Posted : 27 October 2018 10:48:55(UTC)
I think your dealer loves you BigGrin
#17 Posted : 27 October 2018 16:44:26(UTC)
Why?
The dealer did deleted the bill.
I didn´t paid the bill.
#18 Posted : 27 October 2018 21:25:04(UTC)
If the dealer took the signal back what was wrong with it. Do your other signals work OK.
#19 Posted : 28 October 2018 08:27:20(UTC)
I did ordered semaphore and m83 to use signal via CS3.
So i thought both was default?
It´s not necessary to use Lenz LS150 turnout decoder when there is digital semaphore from the Märklin too.
I plan now to build up a new layout since i did bought CS3.
#20 Posted : 28 October 2018 13:45:02(UTC)
Always good fun building a new layout. Look forward to seeing pictures when you start building.
#21 Posted : 28 October 2018 21:19:54(UTC)
2-rail or 3-rail ??
#22 Posted : 29 October 2018 18:18:22(UTC)
2-rail or 3-rail ??
What´s difference??
You can use both of it since CS3 supports mfx,MM2 and DCC.
Even Trix do have mfx for the two rail.
#23 Posted : 29 October 2018 20:09:09(UTC)
2-rail or 3-rail ??
What´s difference??
The difference is the tracks and the rolling stock................... BigGrin
#24 Posted : 30 October 2018 09:22:04(UTC)
2-rail or 3-rail ??
What´s difference??
No
You use same rolling stock in both 2 and 3 rail.
I decides to test Lenz LS150 with an Roco semaphore together with the CS3.
Offline poulmh
#25 Posted : 30 October 2018 09:44:09(UTC)
poulmh
2-rail or 3-rail ??
What´s difference??
No
Good luck.
____________
Poul M Hansen
#26 Posted : 30 October 2018 13:51:15(UTC)
Goofy why don't you use a Marklin signal with the CS3. Problems mixing items from different manufacturers do happen.
#27 Posted : 30 October 2018 15:17:05(UTC)
OK, in that case I would like to hear more about your locomotives.
If you have DC wheels on your wagons, you can't have the 3rd.-rail feedback.
If you have AC wheels, you can't use them on a 2-rail layout.
#28 Posted : 30 October 2018 17:59:31(UTC)
You have ESU locomotive...
#29 Posted : 30 October 2018 20:06:38(UTC)
OK, I was not aware that you only have ESU locomotives.
Have you sold all the others you had?
#30 Posted : 30 October 2018 21:05:57(UTC)
I don't quite understand if your are a Marklin fan why you want to run two rail. Three rail gives much better driving and reverse loops etc and with C track decoders can be placed underneath the ballast etc.
Do ESU locos run on both three and two rail with a slider or is that removed for two rail.
Nothing wrong with two rail and in the past Roco were good with some excellent track but in the end its not Marklin.
#31 Posted : 31 October 2018 20:46:13(UTC)
The ESU I have, there is a tool that you use to pull the slider out for 2 rail operation, which I think, also causes an internal connection change to select power from the two sides rather than the center pickup - like when you plug/unplug a barrel plug from it socket. So its an easy thing to do - though I'd expect not something one would want to do regularly.
#32 Posted : 18 November 2018 09:41:04(UTC)
I have same problem with the m84 too.
The turnout stand red in the CS3 display but on the m84 it stand green light.
This happens when when i turn the power again to CS3.
Does it mean there is bug in the system CS3?
Guest (4)
This page was generated in 0.741 seconds.
