#1 Posted : 25 September 2018 07:40:56(UTC)
Think I have a problem with 2 M83s.
Both have been set to DCC (no 10 Dip switch on) when power is applied the indicator lights on the power connection flash on both units. The only information i can find is that if lights flash on both units the Red and Brown are reversed, No so in this case. checked and did a physical change over. Clues troops clues.
Unsure
#2 Posted : 25 September 2018 08:34:47(UTC)
Did you connected(plugged) two m83 together and feed digital in both?
In case don´t!
Just only one m83 needs digital feed if you did connected two m83 plug into.
#3 Posted : 25 September 2018 09:54:38(UTC)
In case don´t!
NO only one feed in. They were working a few weeks ago but not now. tis a Pain.
#4 Posted : 25 September 2018 12:11:24(UTC)
Try to connect just one m83 and check if there is default.
#5 Posted : 25 September 2018 12:13:36(UTC)
Tip...no power on allowed when you change dip switch or connect the wires!
#6 Posted : 26 September 2018 08:44:58(UTC)
I uncoupled the M83s and connected one unit the light flashed. connected power to the other unit the light flashed.
I coupled the units together but in the reverse order, light flashed on both units. I think they have had it,
#7 Posted : 26 September 2018 08:55:37(UTC)
If the red lighting is flashes normal you did connect right.
If both check lighting flashes the wires has been swapped.
#8 Posted : 26 September 2018 09:01:21(UTC)
I enclose an picture.
You see the wires?
It´s correct connect to the m84.
So that means the left LED flash normal.
if the wires was swapped both LED on the m84 flashes.
#9 Posted : 26 September 2018 14:27:49(UTC)
The wires are connected correctly, the lights on BOTH units are flashing when they should not.
#10 Posted : 26 September 2018 15:13:49(UTC)
No the left red LED flashes normal and both unit do it correct.
It´s normal operation.
#11 Posted : 26 September 2018 15:30:38(UTC)
I enclose an picture here where you can read about the monitor lighting.
This page was generated in 0.302 seconds.
