#1 Posted : 21 September 2018 17:12:28(UTC)
Did just tested turnout motor with the m84.
It works nice!
I did used extern trafo 16 Vac to feed the turnout motor with two diodes to connect half-wave voltage.
The power was digital direct to the m84 and don´t need extern feeder.
thanks 7 users liked this useful post by Goofy
#2 Posted : 21 September 2018 23:51:44(UTC)
Well done Goofy. Good to see you are enjoying your CS3.
#3 Posted : 22 September 2018 08:44:05(UTC)
Thank you!
I shall do some project by test two switchable contact on the tortoise motor via reed contact from the m84.
This page was generated in 0.183 seconds.
