Offline GaryTrooper
#1 Posted : 05 September 2018 01:13:00(UTC)
GaryTrooper
I am looking for the screw specs for the 7072 control boxes. I can't tell what size they are. A #2 is way too big. Is it a #1 or #0 size thread? I am looking to mount some old 7072 control boxes to wood but don't have the longer screws which go through the control boxes into the wood. I believe the length is ~1" or 25 mm.
Any help would be appreciated.
Thanks in advance,
Gary
G - LGB
HO - Marklin
N - Mix of manufacturers mostly Kato
Offline Markus Schild
#2 Posted : 05 September 2018 09:17:12(UTC)
Markus Schild
Hi Gary,
The screws are 2*25mm. If you can't get them elsewhere, Märklin sells them as E786240.
Markus
thanks 6 users liked this useful post by Markus Schild
Offline rbw993
#3 Posted : 05 September 2018 20:26:47(UTC)
rbw993
Point of clarification - that would be 2mm*25mm not a #2*25mm.
A #2 is 2.184mm.
Offline GaryTrooper
#4 Posted : 05 September 2018 20:35:44(UTC)
GaryTrooper
A #2 is 2.184mm.
I figured that. I was locking at #2 wood screws at the hardware store and thinking that the dia. was rather large.
Gary
G - LGB
HO - Marklin
Offline SteamNut
#5 Posted : 06 September 2018 19:28:36(UTC)
SteamNut
Until you get the correct screws try double sided tape as a temporary solution.
Offline GaryTrooper
#6 Posted : 08 September 2018 00:24:12(UTC)
GaryTrooper
Hi Gary,
Markus
I have not been able to find a store in North America which has these screws. Can anyone lend a hand in locating a supplier?
Thank you in advance,
G - LGB
HO - Marklin
Offline TEEWolf
#7 Posted : 08 September 2018 01:42:23(UTC)
Originally Posted by: GaryTrooper Go to Quoted Post
Hi Gary,
Markus
Hello Gary
of course in Europe you get the screws easily. 2 links
http://bwbahn.com/Schraube-Linse-E786240
https://picclick.de/M%C3...-LINSE-291867340908.html
even you get it at the Maerklin shop.
https://www.maerklinshop...chraube-senk-linse-10-st
But be aware about the transportation costs. Most of them suck you. This article is really neither heay nor big, it could be send in a "Versandtasche" (Jiffy bag?) starting at 3,70 € from Germany to the USA.
bwbahn is charging you equivalent to the goods you bought, .e.g up to 50 € they want 12,50 € as delivery charges. So you always have to optimze an order.Smile
http://bwbahn.com/epages...Categories/Versandkosten
A calculator for delivery charges from Germany to the USA
https://www.portokalkulator.de/portokalkulator/std
Also the seller by Picclick is Kieskemper, a dealer in Germany. But perhaps you find another one via Picclick. This platform is an USA based one as far as I know. (I never used Picclick).
Wolfgang
Offline GaryTrooper
#8 Posted : 08 September 2018 01:49:03(UTC)
GaryTrooper
Thank you Wolfgang,
I'll check out the options. Isn't it amazing how the smallest little part can hold up a project? Not that I'm in a rush on this long term project but it seams like the smallest things take the most effort sometimes.
Thanks again,
Gary
G - LGB
HO - Marklin
Offline davo_vespa
#9 Posted : 08 September 2018 08:07:37(UTC)
davo_vespa
Thank you Wolfgang,
Thanks again,
Gary
Hi Gary,
Pretty hard to find these "downunder" so I bought mine from this Ebay seller,
https://www.ebay.com.au/...tem465690b66a&_uhb=1
Happy Days, David
thanks 1 user liked this useful post by davo_vespa
Offline GaryTrooper
#10 Posted : 08 September 2018 17:51:13(UTC)
GaryTrooper
Thank you all for the help and discussion. I was able to get some of these screws online this morning. I am also using the two sided tape trick in the meantime.
There is nothing like having a team of international advisors to help construct a model railroad. BigGrin
Now I am remembering the many hours in the basement pondering how to proceed with a problem as a kid, getting cool ideas from the "masters" at local train shows, and checking out the next issue of Model Railroader or a track plan magazine at the hobby store - but not buying them because I wanted to spend the money on a train.
Thank again all for the help. This forum is a lot fun!
Gary
G - LGB
HO - Marklin
#11 Posted : 08 September 2018 20:37:36(UTC)
another option, Velcro. Glue one side to the panel and glue the other to the surface you want it on.
Though not the same item, see http://cabin-layout.mixmox.com/2014/08/Viessmann-5210.html
#12 Posted : 08 September 2018 20:55:57(UTC)
Any double sided tape would do.
Offline sanoaskosano
#13 Posted : 08 September 2018 21:59:00(UTC)
sanoaskosano
thanks 2 users liked this useful post by sanoaskosano
Offline GaryTrooper
#14 Posted : 19 September 2018 20:00:15(UTC)
GaryTrooper
The screws arrived. BigGrin
G - LGB
HO - Marklin
thanks 7 users liked this useful post by GaryTrooper
Offline TEEWolf
#15 Posted : 20 September 2018 19:03:59(UTC)
wow - many screws.BigGrin
Offline GaryTrooper
#16 Posted : 20 September 2018 19:27:32(UTC)
GaryTrooper
Yes, many screws. 50 to be exact. I only need about 3/4 of the controls mounted on that board for this new layout but is sure does look good!
G - LGB
HO - Marklin
thanks 2 users liked this useful post by GaryTrooper
This page was generated in 0.828 seconds.
