Offline QQQ1970
#1 Posted : 02 September 2018 13:08:44(UTC)
QQQ1970
2018 Fall New Item. Does it come with 1 or 2 motors?
For those of you who have Crocodile, does 1 or 2 motors make a difference in running characteristics?
#2 Posted : 02 September 2018 13:44:18(UTC)
According to the description it comes with one motor - like all the other from the same mould before. Three powered axles.
All my crocs (Roco and Märklin) only have one motor. I have some other models with two motors and I do not think that two motors improve the running characteristics, but that is largely opinion-based.
Offline Alfa V8
#3 Posted : 02 September 2018 14:20:21(UTC)
Alfa V8
It has two motors, one in each engine unit, which drives by gearbox down to the center axle, the wheels on the driven axle are equipped with rubber tires, the drive to the other driving wheels is through the side rods. It weighs 402.5 gram and has a draw bar pull with both units slipping of 95 gram and runs nice and smooth to my eyes. I do not have a crock fitted with a high efficiency 5 pole motor in one engine unit but I have one fitted with the old large C sine motor fitted in one engine unit. The C sine motor fitted unit drives through a gear train to all three axles, the outer four wheels are fitted with rubber tires. The C sine Crock weighs 511.0 grams and has a draw bar pull of a 110 gram, it runs just as smooth as the one with two motors but has a lower minimum speed than the new Crock.BigGrin
You could have a look at it and its twindrive mechanism at the link below
https://www.flickr.com/p...albums/72157695021351090
Hannes
Every day provides new opertunities. H0 mostly Marklin, still using my 6021, LGB in Gauge 1, live steam in larger gauges.
thanks 4 users liked this useful post by Alfa V8
Offline Herrfleck
#4 Posted : 02 September 2018 15:37:42(UTC)
Herrfleck
Hannes
Hello!
The question is not about the Insider model. It is about 39568!!
I think it is like Tom mention in preview post. It is most likely 1motor?
All earlier Ce 6/8 111 are made with 1 motor.
I have crocodiles with 1 motor and with 2 motor.
Both modells runs good.
But I have a Ae 8/14 with 2 motor and it runs not perfekt.
And I have a V188 with 2 motor and it runs perfekt .
Bertil.
- since my lack in english I don't write so much here.. but learn by trying right? :) -
//Bertil
Offline torhb
#5 Posted : 02 September 2018 16:03:39(UTC)
torhb
Views messages in topic : 47
Does the description say it has two motors ?
No ?
Then it obviously has only one motor. Märklin always mentions any extras in the models.
Tor
Tor Harald Bøhler
Oppegård, Norway
Offline Bart
#6 Posted : 02 September 2018 17:37:25(UTC)
Bart
No ?
I concur with your observation.
However, AFAIK, they changed to 2 can motors in 2013, with 37565, 37566 and all subsequent models.
I would be highly surprised if they would change back to the old 1-motor setup now.
*Bart
#7 Posted : 02 September 2018 19:02:46(UTC)
A few years ago they made a new mould with two motors.
Now they make a re-run of the old mould that always had just one motor.
No change back - two completely different prototypes, two completely different models.
Offline Unholz
#8 Posted : 02 September 2018 19:55:56(UTC)
Unholz
May I humbly point out that you are talking about two completely different types/prototypes of "crocodiles"?
The Marklin models featuring two can motors follow the SBB prototypes called Be 6/8 II and Ce 6/8 II (with the slightly complicated looking rod mechanism plus "Blindwelle").
The first Marklin H0 models that were produced (including the vintage CCS 800 / 3015) and also the brown model just announced this autumn all are built according to the Be 6/8 III or Ce 6/8 III prototypes featuring the simplified and more efficient "Winterthurer Schrägstangenantrieb". These Marklin models only have one motor in one of the articulated front power elements.
thanks 4 users liked this useful post by Unholz
#9 Posted : 02 September 2018 20:19:25(UTC)
39568 will be one motor in truck and sound unit in other truck the same as 39565.
Different class class 'Ce 6/8 III' have one motor and class 'Ce 6/8 II' have two motors.
Offline dickinsonj
#10 Posted : 03 September 2018 01:35:36(UTC)
So is Märklin really introducing a new loco with Sine Propulsion? I was away from Märklin for a long while and had never seen that drivetrain before, but I do have the compact C-Sine in a DB Class 01. It pulls ok but the speed is slow and it is not impressive. But from some of the things that I have read I thought that all of the sine variants flamed out long ago.
I have an old 3356 Croc with a dcm power unit and it pulls like a mule, even with the primitive motor and just three axles powered. I also have two of the newer (2014) crocs with two small can motors and they pull very well even though they weigh less than the dcm classic. So it is kind of a wash with the advantage IMO going to all of that dcm torque!
#11 Posted : 03 September 2018 08:05:34(UTC)
Nowadays the 39xxx numbers indicate the loco has "if it's good enough for Märklin then it's good enough for you"-propulsion.
There is no indicator it will have C Sine propulsion. It could be a re-run with the c90 motor, it could have a new truck with a can motor.
The link to the explosion diagram is not working yet ...
Offline ktsolias
#12 Posted : 03 September 2018 08:46:39(UTC)
ktsolias
Märklin stopped the production of models with C-sine motors some years ago. There were a lot of problems with these motors (power consuption, realiability, cost etc) despite their excellent running characteristics.
#13 Posted : 03 September 2018 08:56:52(UTC)
That was years ago Märklin did stoped C-sine motor.
The new crocodile has five pole motor like c90 and the third generation mfx+ sound decoder.
But i find the prices are little too high for the old style model.
Offline ktsolias
#14 Posted : 03 September 2018 09:33:59(UTC)
ktsolias
I agree that the price is too high in comparison with the Insider 2018 croco, wich has two motors, servo controled pantograph and the new TELEX couplers.
Offline dickinsonj
#15 Posted : 03 September 2018 14:35:52(UTC)
I assumed that the C-sine motors were dead, but wondered because Steven compared this model to the 39565, which had that propulsion system. I imagine that Märklin has adapted that old chassis to use a newer and cheaper can motor, but as Tom pointed out there are no diagrams posted online yet.
I agree Anders - that price is way too high. I can buy a new Insider 39567 right now for the same cost as Märklin's full retail price for the 39568, which makes no sense to me. I thought that this model might be intended as a more entry level croc after the expensive Insider loco, but now I just think that it is a really bad deal.
This page was generated in 0.585 seconds.
