Offline John Ferguson
#1 Posted : 29 August 2018 15:15:29(UTC)
John Ferguson
How can you configure RocRail to work with the CS3 plus?
While RocRail indicates that the CS3 is a tested system that works it is not listed in the controller setup screen in RocRail.
Do you just use the Ecos configuration?
Offline fusionfaded
#2 Posted : 29 August 2018 22:23:00(UTC)
fusionfaded
If I remember correctly, there should be an option called mcs2 for the CS2. The CS3 should also work with that, since the protocol to talk to the CS is pretty much the same.
#3 Posted : 29 August 2018 22:56:43(UTC)
John Ferguson
Thank you for the information.
Joh
#4 Posted : 16 September 2018 18:51:33(UTC)
John Ferguson
Tried the msc2 option in RocRail and it works fine with the CS3.
Offline oranda
#5 Posted : 23 August 2020 09:45:06(UTC)
oranda
2 Years after the last message here and probably a new version of roc rail.
I've just tries to add my CS3+ to roc rail and there is no msc2 option in adding a new controller!
But
In the roc rail online guide https://wiki.rocrail.net/doku.php?id=mbus:cs3-en there is a bit about Note: Only direct TCP communication with the CS2/CS3 is supported in the Rocrail Forum.
The protocol I've discovered to add is mbus
Then under Rocrail Properties>> Controller Properties>>Interface
needs to be set a type> TCP
Hostname > (your Cs3 ip address) : 15731
OK then restart roc rail
Connected hopefully:-)
Offline applor
#6 Posted : 24 August 2020 01:35:11(UTC)
applor
Yes it works fine with CS2 as well, been using it ever since the Rocrail change many months ago.
This page was generated in 0.442 seconds.
