Offline marklin 279
#1 Posted : 22 August 2018 18:56:33(UTC)
marklin 279
Hi I recently purchased a Brawa Titlis Bahn funicular and have a couple of questions. I can get it to run but the cabs that are supposed to be lit are not lit. anyone who has a Titlis Bahn or might know why is that. Secondly where can I find replacement cable and wire for it.
Thanks for any help,
marklin279
Offline GlennM
#2 Posted : 23 August 2018 11:02:02(UTC)
GlennM
marklin279
Did you try Brawa, they seem to have good stocks of some spares.
I needed an item a while ago and wrote them an email and had a prompt response, good service
#3 Posted : 24 August 2018 11:18:20(UTC)
marklin279
The cabins are supported by a support wire (black nylon wire) and they are moved by a traction wire. The traction wire brings a polarity to the cabins to light them and to rotate the inside of the cabin.
If they are not lit check the following:
- the traction cable is the original Brawa one and should be the current conducting
- the two half loops of traction wire are insulated from each other and the extremities are not connecting with the other half. Brawa recommends the use of adhesive tape.
- normally the two half loops are connected to the incoming 16 VAC so as to bring power to the gondolas
- the cable between the mountain station and the valley station must be connected
I hope this helps
Brawa Titlis User's manual.pdf (8,783kb) downloaded 70 time(s).
#4 Posted : 10 September 2018 16:33:43(UTC)
marklin279
I have it.
Not only are they lit, they are also rotating.
The valley- and the top-station must be connected. (For the valley-station it is just a single electrical wire that must be connected, going to the top-station). I think the plastic-isolation of that particular cable is black. If that cable is not connected, the thing will still work, but without light and rotation.
Offline huttel
#5 Posted : 22 September 2018 13:41:45(UTC)
huttel
For inspiration ;)
http://huttel.dk/marklin/movies/Marklin2.wmv
Kind regards
Thomas
Carpe Diem!
Märklin HO | Insider | C-Track | Digital | Primarilly DK & D | Era III+IV | PC Control with CS2 (60215), Intellibox & Win-Digipet | http://huttel.dk/marklin
thanks 1 user liked this useful post by huttel
#6 Posted : 24 September 2018 17:22:56(UTC)
Originally Posted by: huttel Go to Quoted Post
For inspiration ;)
Kind regards
Thomas
Nice to hear from you again. It´s been 3 years!
Offline marklin 279
#7 Posted : 31 December 2018 17:27:53(UTC)
marklin 279
Thanks For the Inspiration I needed it!!!
Offline marklin 279
#8 Posted : 31 December 2018 17:46:50(UTC)
marklin 279
Hi Thanks For the Inspiration I needed it!!!
For inspiration ;)
Kind regards
Thomas
#9 Posted : 31 December 2018 23:50:45(UTC)
For inspiration ;)
Kind regards
Thomas
That's what you call a minimalist railroad ... Laugh
I see James Bond ready to leap out at around the 2:15-2:30 mark. BigGrin BigGrin
Guest (5)
This page was generated in 0.599 seconds.
