Offline costing
#1 Posted : 21 August 2018 00:56:31(UTC)
costing
I'm trying to get a Re 3/3 (36332) to talk DCC. I've found that the equivalent Trix model (22390) is DCC-ready and I was wondering if its decoder (242332) could be swapped in place of the Marklin one.
I've also found two alternatives to the proprietary decoders, something small enough to fit the orthogonal position of this decoder. As far as I understand the sound is produced by the board, relying on the SUSI data from the decoder. So:
- Zimo MX634C. It explicitly lists SUSI as feature and enabling it by default.
- ESU LokPilot v4.0 M4 MKL (64618). The only one of the LokPilot versions that mentions SUSI.
Both are cheaper than Trix and keep alive capacitors can be added to them. So a priori I'd take one of these two.
But what is your experience, what would you recommend? Trix, Zimo or ESU? Anything else I should keep an eye on when selecting a replacement decoder?
Thanks!
.costin
Edited by user 21 August 2018 09:57:26(UTC)  | Reason: Not specified
#2 Posted : 21 August 2018 01:16:54(UTC)
In some cases it is better to keep to the manufacturer's parts or products, mainly to do with programming.
Offline costing
#3 Posted : 21 August 2018 12:08:44(UTC)
costing
Ok, it looks like Marklin's mLD/3 (60972) would also be compatible, but I can't find the physical size of the decoder in the manual or anywhere on the web... Can anybody tell me the length to see if it would fit the width of the loco?
And it can also be connected to a keep alive (60974). So yes, keeping with the manufacturer might be an option after all :)
.costin
Offline mario54i
#4 Posted : 21 August 2018 14:33:31(UTC)
mario54i
Watching the drawings of Märklin 36332 and Trix 22390, they are very different for electronics. I see a long decoder ( like a sound decoder ) in the Märklin one and a smaller decoder with an electronic circuit underneath in the Trix one. I think it would be difficult to swap them. Why not using a Märklin mSD3 in the original Märlin 36322 board ? It understands DCC.
FYI, ESU mentions SUSI interface in Lokpilot V4 M4 only, but it exists also in V4 multiprotocoll and DCC only. Lokprogrammer allows to activate it, you lose AUX5 and AUX6 logical outputs. The main difference is that the M4 allows to re-map decoder functions to SUSI functions, but only F0-F15. In the other decoders there is a direct mapping : F0-F28 decoder > F0-F28 to SUSI module.
I looked into the SUSI signal of mLD3 decoders. Besides the different timing from ESU, also the coding seems different. I could decode SUSI signals from ESU and Zimo, but not from the mLD3. I wouldn't be surprised if Märklin have a proprietary SUSI encoding.
Any experience about this ?
Offline costing
#5 Posted : 21 August 2018 14:54:37(UTC)
costing
The manual drawing is completely wrong for 36332. The decoder sits orthogonal to the loco, not along it as in anything else I have. I'll take a picture of it when I get back home. To get an idea of what I mean please take a look at page 24 of the Trix model. In any case, a sound decoder wouldn't fit the width of the loco. The current one is ~20mm long and couldn't be any longer than this.
Sorry, no experience with this, barely found out that this even exists. Lots of things to learn about in this hobby :)
Thanks a lot for the detailed info on the ESU decoders, it's good to know there is potential from others as well. But from what you are saying it sounds like I'd better give Marklin a try first. Will let you know in any case.
.costin
Offline costing
#6 Posted : 21 August 2018 18:20:59(UTC)
costing
Here is the factory decoder in the 36332. It's actually 23mm long.
.costin
#7 Posted : 22 August 2018 10:58:43(UTC)
.costin
I have used quite a few Maerklin mLD decoders for DCC, and as far as I know they are designed to retrofit any Maerklin loco with a 21 pin board.
Your photo of the 36332 shows a 21 pin connection.
Why not phone your local Maerklin dealer and ask about the size and fitting, because that is where you will buy it anyway?
Offline costing
#8 Posted : 22 August 2018 11:19:02(UTC)
costing
Thanks, let's give it a try then.
Due to time constraints I tend to do the shopping online and have everything delivered. That also helps to avoid speaking French, on the phone or in person.
.costin
Offline mario54i
#9 Posted : 22 August 2018 16:01:38(UTC)
mario54i
Size of mLD3 decoder is 23 x 15.5 mm, Lokpilot V4 is 21.5 x 15.5 , Zimo MX634D 20.5 x 15.5 (from catalog)
#10 Posted : 25 August 2018 10:14:18(UTC)
Zimo are excellent decoder.
D&H are same excellent and do have same size of the decoder like other.
If you use DCC i would chose Zimo/ESU or D&H just because they have more features.
Offline TEEWolf
#11 Posted : 26 August 2018 01:11:36(UTC)
Thanks!
.costin
Hello costing,
do I understand you correctly: you already bought the Märklin art #36332? Now you want to run your new Re 3/3 with DCC instead of mfx? Your question is: how does Re 3/3 (36332) from Maerklin run under DCC?
I doubt it that your Märklin Re 3/3 will do it, whereas the Trix Re 3/3 can do it and mfx as well. This might be a serious complain to Maerklin worthwhile. Because both articles (Trix as well as Maerklin) are quite new. First offered in 2015. I did not made a full investigation, but on the Maerklin homepage Re 3/3 is listed only doing the mfx format. On the Trix homepage Re 3/3 is listed doing mfx and DCC!
I had a look in both manuals. Indeed, the Trix manual writes from a multi protocol operational decoder, the Maerklin ones does not! Also the decoder at Märklin has another spare parts # (242 202) than the decoder in the Trix loco (spar part # 242 408).
I would write to Maerklin asking if this is correct: same models but two different types of decoders. If YES, then request them to change your Märklin decoder against a multi protocol decoder for free. It is a misleading for the customers. Märklin is always very proud about its offered multi-protocol decoders and controllers, like the CS 3. Then it is inappropriate to give the same model one time a single-protocol decoder and the other time a multi-protocol decoder. If your Märklin Re 3/3 would have the Trix decoder on board, it would be very easy changing your Re 3/3 locos to the DCC track format for running.
#12 Posted : 26 August 2018 10:30:43(UTC)
Thanks!
.costin
Hello costing,
The answer will be fine.
To run with the DCC on the three rail does not big difference from the two rail.
Offline mario54i
#13 Posted : 26 August 2018 11:58:50(UTC)
mario54i
It's Ee3/3, Re3/3 does not exist
#14 Posted : 26 August 2018 19:14:01(UTC)
It will not be fine with the existing decoder, since it only speaks MFX.
Please try to understand the questions before you answer.
Offline costing
#15 Posted : 28 August 2018 02:02:42(UTC)
costing
Sorry, yes, it's Ee 3/3, not Re 3/3.
I have received earlier today the mLD/3 (60972) and since 5 hours I'm struggling to configure it.
So, what works
- DCC :)
- motor and auto tuning
- light mapping to travel direction
- aux1 disables one of the rear white lights
- aux2 disabled the other of the rear white lights
- both aux1 and aux2 at the same time turn the one rear light red
But I couldn't figure out how to enable driving sounds and to map the sound functions. I don't see anything about how to map conditions to susi functions. Any suggestions for CV values?
As for asking Marklin for help... my mails went unanswered, not a bit of help. Too bad the machines are so nicely done, the level of documentation and support is terrible :(
.costin
Offline TEEWolf
#16 Posted : 28 August 2018 02:32:11(UTC)
So, what works
- DCC :)
.costin
Hello Costin,
do you really bought a mLD/3? This is indeed a very good decoder, but only for locos and no sound possible - mLD stands for "Märklin Locomotive Decoder" - mSD is the "Märklin Sound Decoder".
The sound decoders have the article # 60975, 60976, 60977. The only difference between these decoders is the preinstalled (and of course always changeable) sound. 60975 for steamer, 60976 Diesel, 60977 E-locos.
The 60972 is a decoder without a sound module.
60978 and 60979 are for special locos from the hobby program.
Offline costing
#17 Posted : 28 August 2018 07:17:29(UTC)
costing
I know, it's a bit confusing still. As mentioned above the sound is not coming from the decoder but from the motherboard (the original one seems to be a mLD).
This page also mentions using LokPilot for the 36332 model:
Märklin 36332-1 / BR Ee 3/3
Decoder: Lokpilot V4.0, Besonderheit: Lok hat ein SUSI-Modul mit Sound!
And then there is the fact that no sound decoder on the market is small enough to fit the space there, Marklin included. So back to square one, how to actually configure it to pass susi commands to the motherboard?
.costin
Offline mario54i
#18 Posted : 28 August 2018 19:31:39(UTC)
mario54i
Lokpilot is delivered with SUSI already enabled, I checked also a Zimo and a mLD3 and both had the SUSI signal active.
Offline costing
#19 Posted : 28 August 2018 22:11:31(UTC)
costing
I think the missing step is the decoder programming USB dongle. I've checked out mDecoderTool and it has the option to add SUSI_F* as actions to the received F* calls. I have no idea how this translates into CV settings, the manual is really cryptic in general and particularly void of information in this area. Anyway, I'll let you know in a couple of days if this works.
And in the mean time I got a message from Marklin saying that the mLD/3 is the right upgrade part for this loco. Hurray, it seems I'm on the right track!
Until then another question: how do you figure out which motor type to choose? The options are (CV 52):
1. Softdrive Sine
2. Without feedback control
3. High efficiency propulsion C90
4. Bell armature
5. Direct current DC soft (default)
6. Direct current DC hard
7. Direct current DC 1 Gauge
The default value worked the best, I was more curious in what this advertisement actually translates into:
Digital locomotives with high-efficiency propulsion. ... Special motor with electronically enhanced load compensation or a compact bellshaped armature.
Settings 3 and 4 had funny behaviour even after the auto calibration, for a long throttle range it barely moves, then it's faster, then slower again to finally accelerate decently at full throttle.
A search by the motor part no (E239326) didn't bring any clarity in the picture.
Not a big deal, it works ok as is, just trying to build a knowledge base :)
Thanks a lot for your answers so far,
.costin
Offline costing
#20 Posted : 30 August 2018 00:02:55(UTC)
costing
The decoder programmer dongle has arrived today. And indeed in its software I could set the SUSI functions to be called and everything works now. It required a bit of probing to figure out that SUSI_F0 is the master switch for the sounds and that the rest are not in sequence afterwards, with gaps in between. I'm attaching the project file for reference (to be renamed to .mdtp) Ee33.zip (8kb) downloaded 31 time(s)..
I'll recap the story in case others stumble on the same problem:
Marklin Ee 3/3, model 36332. Original decoder is an mLD. Replaced with mLD/3 (60972) to have DCC. This or one of the non-sound decoders, of less than 23mm in length, from the other companies were the only options since the space inside is very limited.
Original loco has the sound module on the main board, it's independent of the decoder and has to be driven by SUSI commands. I didn't manage to figure out how to map the F* calls to SUSI functions from CVs. Using the programmer (60971) makes this trivial however.
Another tricky bit, with the new decoder the sound volume was reset to zero and this took me a while to figure out. This is something else I haven't figured out how else to do, had to go back and use mfx to set the volume and then everything simply worked in either protocol.
So the last part of the puzzle is how to change the master volume from DCC.
Anyway, I'm happy that everything turned out all right in the end. Many thanks to everybody for your help along the way!
.costin
thanks 2 users liked this useful post by costing
Guest (4)
This page was generated in 0.585 seconds.
