Offline Torrid
#1 Posted : 06 August 2018 19:36:17(UTC)
Torrid
HELLO ALL MEMBERS,
I HAVE A PROBLEM CONNECTING MY CS3 TO MY PC RECENTLY.
LAST TIME I CONNECTED ONE OR TWO MONTHS AGOI HAD NO PROBLEM.
I AM USING TJHE IP ADDRESS AS SHOWN ON THE CS3 FOLLOWED BY :5900
HELPWILL BE MUCH APPRECIATED.
THANKS
#2 Posted : 06 August 2018 23:25:55(UTC)
As you are shouting out that you are using port 5900 it is expected that you also have (installed) a VNC client on your PC
To use the VNC server on the CS3 you need to start it after every power on.
Once started, the client will be able to connect on port 5900 (provided it is on the same network)
Offline dickinsonj
#3 Posted : 07 August 2018 01:05:19(UTC)
Can't he just use the IP address without the port number?
I don't have one yet but from what I understand the CS3 stands up a very nice web server and most browsers will work just fine as clients. That makes it easy to add additional interfaces to the CS3 without dedicated software. Cool
Not sure wtf the all caps stuff is about though. BigGrin
#4 Posted : 07 August 2018 05:31:47(UTC)
That will , indeed, present a Home-page from where a number of functions can be found , including ...
- enabling the VNC server - for use with a VNC client
- start the CS3 webclient - a browser solution for any (major) platform that does not need a separate VNC client installed
- Loco icon management
- Screenshot - for recording images for documentation or service purposes
- Status etc.
Offline Torrid
#5 Posted : 07 August 2018 16:23:10(UTC)
Torrid
HI ALL,
THANK YOU FOR YOUR COMMENTS.
WHICHEVER WAY I TRY WITH OR WITHOUT A VNC VIEWER I JUST CANNOT CONNECT REMOTELY.
THIS IS DRIVING ME CRAZY.
Offline Torrid
#6 Posted : 07 August 2018 17:30:07(UTC)
Torrid
Hello again,
It worked at last, I did nothing different at all???
thanks to all.
Confused Confused BigGrin
#7 Posted : 07 August 2018 19:38:21(UTC)
If there was no change, did you try a different cable and/or reset the wifi router?
Offline Torrid
#8 Posted : 07 August 2018 21:00:36(UTC)
Torrid
HI MINOK,
THE ONLY THING I CAN ADD IS THE ROUTER WAS TURNED OFF LAST NIGHT.
#9 Posted : 07 August 2018 21:29:52(UTC)
So then the question is, does the CS have an IP address assigned to it? I'd assume in the CS you can see if its gotten an IP address and what it is, and in the router you can see if there is a fixed IP address or DHCP assigned IP address (meaning the CS is connected up to the TCP/IP network LAN properly). Check that the CS is actually active on the LAN first, without that the http/vnc/etc higher level facilities won't work.
In the US we just got the latest digital news letter (PDF) that explains how to connect a CS3 via web browser, a beta test feature that came with the v 1.3.3 update to the CS3 family.
I've attached it to this post here: 20180704-update_1_3_3_info-04 Englisch.pdf (760kb) downloaded 33 time(s).
It mentions a sequence in powering on things, which could be the problem:
1) Router on
2) Then master CS3 on
3) then other devices on.
Offline Torrid
#10 Posted : 08 August 2018 08:09:45(UTC)
Torrid
HI ALL,
THANKS, YES THE IP ADDRESS IS EASILY READ FROM THE CS3.
THANK YOU MINOK FOR TAKING TIME TO PROVIDE ALL THESE DETAILS AND THE VERSION 1.3.3 UPDATE info.
I HAD PREVIOUSLY UPDATED TO THE LATEST VERSION A WEEK AGO AND HAVE NO ISSUES THUS FAR.
#11 Posted : 08 August 2018 16:48:38(UTC)
Then we need to look at more fundamentals:
IP address of he CS
IP address of the computer
Netmask of the LAN
This way we can verify the 2 are on the same LAN.
Offline Torrid
#12 Posted : 08 August 2018 17:12:24(UTC)
Torrid
Thanks Minok, I will delve a bit further.
This page was generated in 0.452 seconds.
