Offline andrews
#1 Posted : 25 July 2018 03:14:19(UTC)
andrews
Does anyone have experience using Azatrax infrared detectors and TS2 or TS2-D signal controllers with Viessmann signals, specifically models 4010, 4011, and 4014? I am planning to set up a section of my layout with 3 or 4 blocks where the movements of the trains control the indications of the block signals. I don't plan to include any kind of train control. It seems this combination should work ok. Any suggestions or lessons learned from experience would be appreciated. Thanks.
Offline Danlake
#2 Posted : 25 July 2018 08:49:55(UTC)
Danlake
Hi Andrew,
I haven’t used the infrared sensors with signals but instead with occupancy detection. For that application it has worked flawless and as reliabable as contact tracks. I don’t recall ever having false signals and whether night or day in train room it works.
I use the options across the track detection. Make sure you install them at an angle (that is not perpendicular to tracks).
If you can find documentation that it should work with Viessmann type signals on their website I am sure it will. Else drop them an email (I got very fast replies from the owner when I had some inquiries.
Best Regards
Lasse
Offline andrews
#3 Posted : 27 July 2018 01:49:42(UTC)
andrews
Hi Andrew,
Best Regards
Lasse
Thank you Lasse for the information. The Azatrax people were very helpful. I have ordered the sensors, controllers, power source and signals so I will be trying them out soon. Azatrax did tell me that the the controllers have regulators that limit the output to the signals to 5 volts DC and there are resistors on the circuit boards with values that keep the LED current to a safe level. Therefore, I will have to remove the resistors that come with the Viessmann signals. If I leave the resistors on the signals the LED's will be very dim or may not work at all. I will let you know how the results of the experiment.
thanks 1 user liked this useful post by andrews
Offline DTaylor91
#4 Posted : 27 July 2018 07:07:20(UTC)
DTaylor91
Originally Posted by: andrews Go to Quoted Post
Hi Andrew,
Best Regards
Lasse
A suggestion: Instead of removing the resistors, especially if they are difficult to remove, or are surface-mount resistors, short them out instead. It'll be faster, and less likely to cause damage. I suggest bridging them with a wire clipping, or using a dab of conductive paint to bridge a surface-mount resistor.
I've never seen the inside of a Viessman signal, so not sure what you'll find.
Hope this saves you time and trouble...
#5 Posted : 27 July 2018 08:49:16(UTC)
The resistors for those types of Viessmann signals (4011, 4012, etc) are soldered to the ends of the signal fly leads, so no problem to remove them.
Offline andrews
#6 Posted : 11 August 2018 02:31:51(UTC)
andrews
I now have some experience with the Azatrax controllers and the Viessmann signals, so thought I would share my results. 1. The infrared sensors are reliable in dark and bright light conditions. 2. An LED with the resistor attached appears to be just as bright as an LED with the resistor removed. 3. On my test track I have 3 blocks. The eastbound signals are #4012 entry signals wired so each of them alternates between green, red, and yellow, the same as 3-color block signals do here in the US. The westbound signals are #4014 block signals with advance signals, wired so the advance signals are controlled by the aspects of the next home signals. Both types of signals change aspects as expected. Verdict: definitely consider Azatrax products for occupancy detection and signal control.
thanks 2 users liked this useful post by andrews
This page was generated in 0.512 seconds.
