Offline Ben Dutton
#1 Posted : 21 July 2018 00:06:25(UTC)
Ben Dutton
I and a friend are setting up a new Marklin System.
We have a mini control station with the required accessories to operate.
I am pretty sure we have set up the controller and track correctly.
We placed one of our MFX locomotives on the track and went through
the procedure to have it recognized. MFX flashed for a second, but
nothing further. This was a Marklin 39979; Railbus Roterflitzer.
This unit did work correctly on a Rocco "Smart Rail".
We Placed another MFX locomotive on the track. This was a 37168 -
BR 94.5 "steam Locomotive". With this unit, the controller flashed MFX.
then it all the are lit up with the correct locomotive name, with the correct
controls next to the proper buttons. And it operated extremely well.
I noticed that scrolling through the Locomotive database on the controller
I could find the second locomotive, but not the first. Is this the root of the
problem? I ask because the manual makes it appear that if the Locomotive
is an MFX unit, all it parameters are uploaded from the Locomotive to the
controller (rather like plug and play on a computer). Or does the MFX just
tell the controller were to go in its internal database to get the proper
operating parameters?
If the problem is due to the unit not being in the database, what is the best
work around? We have had no success trying to program the mini controller.
Would generating a locomotive card from a CS2 or CS3 be a viable alternative.
We have made some progress by reading the German Manuals and Blogs.
The English instructions were somewhat lacking.
Any help you can provide would be greatly appreciated.
Ben Dutton
thanks 1 user liked this useful post by Ben Dutton
#2 Posted : 21 July 2018 11:30:40(UTC)
Ben Dutton
Ben, when you say "mini controller", are you referring to a Mobile Station?
Can you give the item number, it may be marked on the underside
#3 Posted : 21 July 2018 13:58:01(UTC)
Ben Dutton
The 39979 is an mfx item, but my experience is that you need to turn off mfx in the decoder to get them to work on a smartrail. So did this get turned off and you have failed to turn it on again in the decoder when you tried with the "mini system" (I presume you mean an ms2 by this).
Offline Ben Dutton
#4 Posted : 21 July 2018 21:33:25(UTC)
Ben Dutton
Ben Dutton
It is the mobil station
and it is black, which I believe means it is the newer model
I will have to get the model number.
Ben
Offline Ben Dutton
#5 Posted : 21 July 2018 21:39:45(UTC)
Ben Dutton
Ben Dutton
Ben
Offline Ben Dutton
#6 Posted : 21 July 2018 21:57:57(UTC)
Ben Dutton
Ben Dutton
yes, this is a mobil station. We have not made any adjustments to the Locomotive. We do not know how to turn the MFX off and on.
However the Locomotive that is not recognized on the mobil station, was first placed on the smart rail, where it worked. could this have turned mfx off. If so, how do you turn it back on.
Thanks for any help
Ben Dutton
#7 Posted : 22 July 2018 13:45:06(UTC)
Thanks for any help
Ben Dutton
Make sure this is the only loco on the track and when you turn on the cs2 there is an option to change CV values. Look in the ms2 manual to find out how to reset the locomotive. I don't have the instructions for either unit with me, so cannot guide you any further with this, but I'm sure that someone else will.
Offline TEEWolf
#8 Posted : 23 July 2018 04:36:55(UTC)
problem?
Indeed it could be. The MS 2 has 2 databases. The 10+1 you see at the display and an internal one for 40 spaces. If your loco is not in one of the databases the information has to come from the mfx decoder. If that one is not functioning, you must add your digital address manually.
https://www.maerklin.de/...faq/Technik-Tipp-307.pdf
https://www.maerklin.de/...faq/Technik-Tipp-306.pdf
If mfx is working properly, it is a plug & play system. But yours is not working. So you have to programm your decoder manually and save it to the decoder.
Yes. But you had no sucess before, so delete the loco from all your MS 2 databases (if it appears somewhere) and make a reset of your decoder before you start programming again.
Ben Dutton
Hello Ben,
you are providing a good description what is happening, but unfortunately not too much about the technical articles. So I guess you are using a MS 2 art #60657?
After reading some German threads about this topic it is not so rare as I first thought. But:
- do you have access to a CS 2 or CS 3?
- have you tried to register your mfx loco manually?
- have you tried to create a loco-card and get the loco registration via a loco card?
You can try to write the loco card either by a CS 2 or CS 3 or by a MS 2.
As far as I understand the discussion in the German threads, some different reasons can cause problems of a mfx decoder not registering. But you wrote the mfx sign was flashing for a short moment than happens nothing, so your appliances must work but perhaps not your decoder.
Of course, you used the decoder with Roco. I am not experienced with Roco, but perhaps it may have switched the fomat to a DCC standard. Roco cannot use mfx as a track format. There you wrote it was running perfectly under Roco somebody must have changed your railbus to a DCC format.
But also possible: your decoder is damaged. Then either you send it back to Märklin to get the decoder changed. Or you buy a new mSD/3 and install it by yourself. Could be by the horrendous shipping prices from the USA to Germany perhaps cheaper as sending them back to Märklin.
Offline Ben Dutton
#9 Posted : 23 July 2018 19:50:21(UTC)
Ben Dutton
Ben Dutton
It was indeed a mobile station
Part of Marklin digital starter set 29000
the mobile station is part number 60657
Offline Ben Dutton
#10 Posted : 23 July 2018 19:52:55(UTC)
Ben Dutton
problem?
Ben Dutton
Hello Ben,
We would have to send the mobile station back
to our dealer in Chicago, IL. We are located in
Alexandria, VA.
Offline Ben Dutton
#11 Posted : 23 July 2018 19:58:09(UTC)
Ben Dutton
Ben Dutton
Offline Ben Dutton
#12 Posted : 23 July 2018 19:59:42(UTC)
Ben Dutton
Ben Dutton
Alexandria, VA.
Offline TEEWolf
#13 Posted : 24 July 2018 04:22:53(UTC)
Alexandria, VA.
Thanks for the information.
You decided to quit with the mfx-system from Märklin? Getting back to Roco?
Although your track package 29000 is really a good one. And as you wrote in your first post, it was only the rail bus not working. This red rail bus is famous for wrecking quite often. While your steamer loco was functioning very well. So it cannot be any damage at the 29000 set. Otherwise your steamer would not have run.
Sorry, I forgot to write, at the moment in the Märklin Magazine (MM) a series about the MS 2 is published. Unfortunately I only can sent you a link to the German version for these articles although the complete MM paper is available in English too.
The MM https://www.maerklin.de/...ournal/maerklin-magazin/
The series about the MS 2 - it is a pitty that you cannot get access to the download area for these articles via the English part of Märklin's websites. You must go via the German version.
https://www.maerklin.de/...men-specials-und-serien/
http://streaming.maerkli...e_Station_MM_2018_01.pdf
http://streaming.maerkli...e_Station_MM_2018_02.pdf
http://streaming.maerkli...e_Station_MM_2018_03.pdf
These 3 articles are published at the moment and another 3 are announced.
If you want to translate them, I can recommend you this translating software
https://www.deepl.com/translator
This page was generated in 0.664 seconds.
