#1 Posted : 12 July 2018 04:26:53(UTC)
so 11 years ago I made a simple K83 tester:
http://cabin-layout.blogspot.com/2007/03/k83-tester.html
I looked at the page again today and it struck me that there is no diode in the circuit!
I can't recall if the output of the k83 is DC or if it is AC? if it is AC I would expect the LEDs to dislike the reverse current each cycle.
Anyone know?
#2 Posted : 12 July 2018 11:52:11(UTC)
A k83 (Marklin 6083,60830) "yellow" provides a pedestal -22V DC
(worth noting that the m83 (Marklin 60831,60832) provides -16V DC)
The Red and Green outputs switch/pulse to provide a path "down" (from Ground/0/Common )
(worth noting that the m83 uses a trickle/monitoring current which will appear to show the LEDs on in the non-energised state. thus you need a pull-up resistor to turn LEDs off fully)
example =
https://www.marklin-user...s--CS3--m8--2#post442831
Thus your LEDs will have their cathode (flat) towards the yellow.
#3 Posted : 12 July 2018 14:05:43(UTC)
OK thanks for confirming it is DC. I must have measured it and aligned the cathodes correctly!
Offline applor
#4 Posted : 12 July 2018 23:47:15(UTC)
applor
edit: miss-post.
Edited by user 24 July 2018 01:54:33(UTC)  | Reason: Not specified
#5 Posted : 13 July 2018 15:14:41(UTC)
I think you rpost is on the wrong thread.... but I always thought it allowed the customer to place the pole as far away from track center as needed, and they can then cut to whatever length is needed.
#6 Posted : 13 July 2018 16:55:37(UTC)
Hi Dale,
The most important things have been said above
On the Following link you can find the "Schaltplan" (electrical diagram) of a 6083
http://www.jaray.ch/eisenbahn/k83.htm
This page was generated in 0.256 seconds.
