Offline dodo57
#1 Posted : 01 July 2018 20:27:39(UTC)
dodo57
Mexico
I was wondering if somebody knowscabout making your own contact tracks for M-track? (from a common 5100/5106 M tracks)
Offline Markus Schild
#2 Posted : 01 July 2018 20:45:32(UTC)
Markus Schild
Welcome to the forum.
Here someone published an instruction: http://www.modelleisenbahn-analog.de/?p=166
Maybe google helps translating. He uses shrinking tube to insulate a part of rail.
Markus
Offline Gregor
#3 Posted : 02 July 2018 09:11:16(UTC)
Gregor
Another way of doing this is described inthis post.
Gregor
Offline dodo57
#4 Posted : 02 July 2018 18:44:11(UTC)
dodo57
Mexico
Thank you so much Markus and Gregor! Very helpful....
Offline PeFu
#5 Posted : 03 July 2018 08:32:41(UTC)
PeFu
When I had M tracks, I used the Littfinski RM-GB-8 unit instead:
https://www.ldt-infocent...sbeispiele/page_1342.pdf
Works very well, and there is no need of adjusting the tracks ThumpUp
#6 Posted : 03 July 2018 09:26:47(UTC)
Yes.. I use the Viessmann 5233, which is the equivalent of those LDT uints, on my 5200 curve tracks. However, they only detect a current running through a slider. So they are good for intermediate sections (i.e. detection sections between start/stop/braking sections), but not for start/stop sections as the loco stop point will depend on the location of the slider..
It is a real shame that Marklin did not make 5200 series contact tracks.. Sad
Offline amartinezv
#7 Posted : 03 July 2018 09:54:37(UTC)
amartinezv
Hello
I use the following method:
I stick a sheet of kitchen film on top of the rail to be insulated, and on top of this film I stick a sheet of aluminum foil, I solder a cable and that's it.
you can see Here
Antonio Martínez
www.raildigital.es/davidruso
Offline dodo57
#8 Posted : 04 July 2018 00:05:32(UTC)
dodo57
Mexico
Thank you, PeFu and xxup.
amartinezv: qué idea genial y simple!, no sé porqué no se me ocurrió....muchas gracias, es la mejor que me han dado....
This page was generated in 0.539 seconds.
