#1 Posted : 14 June 2018 23:44:11(UTC)
The 7286 turntable is dead with 7687 decoder.
I removed from the layout and testing the turntable but still dead.
I suspend operation running trains layout without TT.Crying
#2 Posted : 14 June 2018 23:53:11(UTC)
....mine's dead too! Cursing
Same day as yours?
Must be an epidemic somehow.Crying
Will have to investigate. It's fitted with a Littfinski decoder.
My suspicion at this point is that the problem is in the TT electro-mechanics, not the decoder.
Maybe some one has some expertise trouble shooting these?
Schematics anyone?
#3 Posted : 15 June 2018 10:54:14(UTC)
Here is a German description of a conversion of the 7286 TT from Maerklin 3-rail to Fleischmann 2-rail standard. There are many diagrams (and some photographs) of the "Maerklin status" before conversion which might help?
https://www.mdvr.de/down...rehscheibensteuerung.pdf
#4 Posted : 15 June 2018 15:39:44(UTC)
Hi Steven
Have you tried to use your TT with the manual control?
I suspect you need to open your TT , remove the bridge and inspect it;
- good contact with rotary contacts
- possible cable break under the TT pitt
- possible burning of one of the 3 diodes to activate the solenoid
A simplified schema is here Schema
It is simple to test both the motor and the solenoid by using a DC transformer with a low voltage 5 to 10 V Of course the decoder is disconnected
I hope this helps
#5 Posted : 16 June 2018 12:46:37(UTC)
I test the turntable is now working with blue controller but the decoder not test with CS2.
I need to find control unit with keyboard soon.
#6 Posted : 16 June 2018 16:13:37(UTC)
Thanks AK, something to get started on the right track!
Jacques
Offline applor
#7 Posted : 22 June 2018 03:49:35(UTC)
applor
This google translated thread gives details on how the turntable mechanics work, it should be of help (helped fix my turntable problem)
https://translate.google...-7286.html&edit-text
This page was generated in 0.566 seconds.
