Poll Question : ESU or CS3plus
Choice Votes Statistics
(Poll is closed)  Total 31 100%
Guests can't see poll choices and poll results. Try login or register. Guests can't vote. Try login or register. The poll has expired.
2 Pages<12
#51 Posted : 31 May 2018 18:12:19(UTC)
The fact is the problem with the Märklins decoder and theirs system do often failure.
I suggest you stop with your undocumented utterings and go with what ever digital system you use this week. I am sure you will be a happier man. Märklin is clearly too complicated for you.
I´m not alone who did had problem with the Märklins decoder.
I see in the youtube how Märklinist change out decoder to another manufactured and are more happier to use it.
I have ESU locomotive and it works better than Märklin with mfx.
If i did changed out decoder in the Märklin trains i would do it.
I would also choice Ecos by to have possibility use ESU decoders resources.
It´s my recommended.
Offline MaerklinLife
#52 Posted : 31 May 2018 19:50:54(UTC)
MaerklinLife
What are those problems? You always fail to explain.
One guy on Youtube? That is your documenation? O N E guy? Really? I would say, that is a pretty good track record in Märklins favour.
For the record I believe you are talking about Wilstein (beautiful layout btw.) and the episode where he changed a Märklin decoder for ESU because he "liked the ESU sound better". A personal preference. Nothing else.
Really? How? Please explain.
thanks 3 users liked this useful post by MaerklinLife
#53 Posted : 31 May 2018 20:30:18(UTC)
I don´t understand why you provocation with false information.
Which false information??
You are now using Lenz, and when you had at MS2 you didn't update it, according to what you write.
Holding a CS2 or a CS3 for 5 minutes in a shop is not "testing"; but just "trying".
Even when your tracks are dirty, you blame Märklin. LOL
The latest update i did had on the Trix MS2 was 2.5 for 3 years ago.
Yes i use Lenz today.
No i did really testing both CS2 and CS3.
I did cleaned Märklin tracks with chemical gasoline 5 times and still Märklins track oxid while you have digital power remain on.
Flapper Flapper Flapper
I suggest TS to buy both CS3 and Ecos if TS feel unsure so why not both of it?
Maybe you could clean the loco wheels and the pick up as I dont see any problems with C track if cleaned once per week.
Why would anybody want to buy both a CS and an ECOS.
2 Pages<12
This page was generated in 0.264 seconds.
