Offline MalinAC
#1 Posted : 31 May 2018 17:15:53(UTC)
MalinAC
Ireland
Hi guys ,I just got a nice 3070 Tee set good condition with box but no paperwork.When I went to put it together I found out that the drive unit is missing the plug to connect to the middle unit. All thats there are 3 wires, red,, white, and blue. Center unit is fine as is the end unit.Im sure the front unit should have a plug .The end of the wires are like whats on the 451 crane to connect the magnet wires to cab Can I get the 3 pin plug and which wires go where on the plug. The drive unit works fine but thats all I can test without that plug. Regards Eddie
#2 Posted : 31 May 2018 18:52:11(UTC)
Hi Eddie, I have the 3071 which is a little different and has only two wires between units, but mine has a plug at one end and a socket at the other end of the centre unit(s). Maybe the ends of the wires you have will fit in the socket on the middle unit? Have you tried?
Offline MalinAC
#3 Posted : 31 May 2018 18:59:49(UTC)
MalinAC
Ireland
Hi Ray, the middle unit is the same, but I dont want to short anything out by putting the wires in the wrong place. I assume one of the wires is the feed but dont know which is which.Eddie
Offline Gregor
#4 Posted : 31 May 2018 19:03:31(UTC)
Gregor
I made one myself using 3 nails and a blob of hot glue.
thanks 4 users liked this useful post by Gregor
Offline TEEWolf
#5 Posted : 31 May 2018 19:14:31(UTC)
Try it here:
https://www.ebay.de/b/Ma...281/bn_7004693130?_pgn=2
https://ttn-shop.com/ers...;spur=H0&lok=3070tee
http://www.khpretz.de/ma...itungen/anleitungen.html
They have your manual, but will charge you 10 € for a download.
https://www.angebote.aht...fd2e479bd685bdd7543c019b
https://www.maerklin.de/...elnummer=3071&lang=1
here is a circuit diagramm, perhaps it helps
https://www.ad-soft.ch/moba-umbau-marklin-3071/
forgot this link, they offer a spare part for your train
https://picclick.de/M%C3...rwagen-323134206966.html
thanks 4 users liked this useful post by TEEWolf
Offline MalinAC
#6 Posted : 31 May 2018 20:36:27(UTC)
MalinAC
Ireland
Thank you ,RayF, Gregor and Tee Wolf, I think I will go with the part from TTN shop. I should be able to work that without too much trouble. Again ,thank you guys for taking the time to answer. Eddie
Offline Markus Schild
#7 Posted : 01 June 2018 06:21:00(UTC)
Markus Schild
Hi Eddie,
My father has drawn this diagram for the 3070 nearly 20 years ago. I added some translations:
Edit: BLAU = blue
Markus
thanks 6 users liked this useful post by Markus Schild
Offline MalinAC
#8 Posted : 01 June 2018 08:22:49(UTC)
MalinAC
Ireland
Thanks very much Markus,Its nice to see where and what the wires go to . Very useful . Eddie
This page was generated in 0.449 seconds.
