Offline GaryTrooper
#1 Posted : 24 April 2018 16:34:30(UTC)
GaryTrooper
Does anyone have the schematic for the electronic module used in the 3322 locomotive. This module seems to be short lived in a production point of view. Any history on the development of the module, and its death to make way for digital would be appreciated.
Thank you,
G - LGB
HO - Marklin
N - Mix of manufacturers mostly Kato
Offline ktsolias
#2 Posted : 24 April 2018 17:22:14(UTC)
ktsolias
Thank you,
A photo will help a lot
Costas
Offline GaryTrooper
#3 Posted : 24 April 2018 17:59:43(UTC)
GaryTrooper
I can post some tonight.
G - LGB
HO - Marklin
Offline TEEWolf
#4 Posted : 24 April 2018 18:40:38(UTC)
Thank you,
Does this help?
http://www.maerklin-samm...omotiven/03322/03322.htm
Also you find these links in the above mentioned link, here for your convenience
http://www.maerklin-samm...omotiven/03022/03022.htm
http://www.maerklin-samm...en/03322/03322_explo.pdf
http://www.maerklin-samm...22/03022_bedien_0644.pdf
While I was searching for you a "schematic for for the electronic module",I found this page.
http://www.osterthun.com...Kat~1986-87~krokodil.htm
Both are 3322 Märklin models.
Offline GaryTrooper
#5 Posted : 24 April 2018 20:27:12(UTC)
GaryTrooper
Thank you,
Does this help?
That is some good information and history. I don't see a description of the electronic module this locomotive has. The module is not digital. It is alanolog and has a rectifier and possibly a voltage regulator. Pics to follow in few hours when I can access the net.
G - LGB
HO - Marklin
Offline GaryTrooper
#6 Posted : 25 April 2018 03:31:36(UTC)
GaryTrooper
Thank you,
Costas
G - LGB
HO - Marklin
Offline ktsolias
#7 Posted : 25 April 2018 08:15:07(UTC)
ktsolias
Thank you,
Costas
OK Gary
We got the think
Is the old electronic circuit very common in 33xx series which was connected with the universal relay to improve the performance when changing direction.
The plan is the follow
Any way may be is time to update this beauty either with a newer fully electronic reversing unit (there are a lots around and the cost is the mail) or even better to upgrade the loco with the 60944 motor and a modern decoder.
I have done the digital upgrade in a 3022 and in a 3159 and believe me even in analog operation is worth the effort!!!
Costas
Offline GaryTrooper
#8 Posted : 25 April 2018 15:07:39(UTC)
GaryTrooper
There it is! Thanks so much for help Costas.
G - LGB
HO - Marklin
thanks 1 user liked this useful post by GaryTrooper
#9 Posted : 28 April 2018 12:29:52(UTC)
Bryan
Dear All
In the parts list for the loco 3322 is the electronic reverse unit 614860. This is still available from Marklin. I presume this is the general replacement for all electronic reverse units for Marklin locos 33* and 34*. I have one of these 614860 units, however cannot find a wiring diagram for it.
There are eight leads, two orange, a grey and yellow. These four I presume are for the lights either end. The red and brown are they the supply? There leaves the blue and green wires which must go to the field coils. Lastly the black which goes to the motor. The return from the field coils goes to the motor.
I connected the red and brown without any other leads with voltage and it started to over heat. I cannot understand why this happened. There was no load.
Does anyone have a wiring diagram for the 614860 unit.
Any suggestions would be greatly appreciated.
Bryan
Offline GaryTrooper
#10 Posted : 28 April 2018 18:30:01(UTC)
GaryTrooper
Originally Posted by: Bryan Go to Quoted Post
Dear All
Bryan
Apologies, I don't have the information you requested but it would be interesting to see a photo of the module you talking about.
G - LGB
HO - Marklin
Offline TEEWolf
#11 Posted : 28 April 2018 18:52:58(UTC)
Dear All
Bryan
Bryan I found an old thread from the memeber @franciscohg at MUN
https://www.marklin-user...377_Converting-3556.aspx
Does it help?
I inserted the German words "märklin umschaltrelais schaltplan" into the German Google search function and got plenty of wiring diagramms. Of course I do nt know, if they are the types you are looking for.
#12 Posted : 29 April 2018 06:26:56(UTC)
Bryan
Reverse unit 614860.pdf (47kb) downloaded 38 time(s).
Hi TeeWolf and Garry
This is the photo of the electronic reverse unit 614860. It is missing a capacitor when I applied 16VAC from a Marklin 66470 controller. It basically dropped of the board when it heated up after a few seconds. I connected it to the red and brown wires, nothing else and it started heating up. I will try the search on Google DE for the wiring diagram. The reason I would like to know about the 614860 is that it should be a direct replacement for the old mechanical electro reverse units such as 208240. The part is very expensive more than a MM conversion set, however I would like to get the 614860 working. I will try Marklin Service as well for the diagram. There may be a better electronic reverse in their stores they can suggest.
Bryan
thanks 1 user liked this useful post by Bryan
Offline TEEWolf
#13 Posted : 29 April 2018 17:19:33(UTC)
Thank you,
Hello Gary,
after surfing in the internet and reading some threads in German communities I found another one here in marklin-users.net too. You are not alone.BigGrin
https://www.marklin-user...Reverse-Unit-going-crazy
This thread is from 2006 !!! and explains everything. I would follow the advice in post #2 from @David Dewar. But allow me writing it in much more drastically words: get rid of this analogue sh.. and change to digital.
A good and cheap possibility is still offerd by Märklin:
https://www.maerklin.de/...s/details/article/60760/
and you get rid of all your "Fahrtrichtungsumschalterprobleme" (isn't it a nice German word?Love - I would translate it as "problems with the reverser for direction of movement"Laugh ) from the 80ties. This is about 30 years ago!
Of course you also can use the mSD3 decoders
https://www.maerklin.de/...er-der-neuen-generation/
This one I would recommend. More expensive, but much better and higher technology and performance. E.g. they all can mfx, sound, etc.
Finally in one post, I read Märklin had a reject rate up to 40% on this electronic part in the 80-ties. No wonder why it was only a short period in production.
Here is the way to digital:
https://www.maerklin.de/...3_Special_MM_2016_03.pdf
Yes it is in German, but it was published in the Märklin Magazine 03/2016 and so it shall be available in English somewhere. A similar article you will find in this English book:
https://www.maerklin.de/...s/details/article/03092/
This page was generated in 0.562 seconds.
