Offline railfanwai
#1 Posted : 22 April 2018 00:29:29(UTC)
railfanwai
Hi , I have a Trix Schnabel Car 24 axles 24338 , it has been assembled already, just wondering how to take them apart n put it back to the box,those plastic bolts u can snap it into the holes and the holes get bolted but i can’t take it out even though I tried to use a tweezer to squeeze it , to no avail!
Online JohnjeanB
#2 Posted : 22 April 2018 13:00:02(UTC)
Hi Railfanwai
I don't have the 24338 car but from the pictures seen on the web I assume it is linked with the difficulty to unsnap those plastic axles as in regular car bogies.
If it is, then you may ease the unsnapping by using long nose flat pliers to force (gently) close the 2 sides of the bogie axle while pulling away the bogie.
Offline railfanwai
#3 Posted : 22 April 2018 20:59:29(UTC)
railfanwai
Hi Railfanwai
Thanks. I’ll try
Offline railfanwai
#4 Posted : 23 April 2018 01:19:55(UTC)
railfanwai
Hi Railfanwai
https://www.google.ca/se...mp;imgrc=Vgd77E8kVpU1WM:
Offline railfanwai
#5 Posted : 23 April 2018 01:27:12(UTC)
railfanwai
Watch video above please, that plastic bolt is under the end of the girder, so it’s between girder n bridge, actually I haven’t tried to take it apart yet, because I have to take off screws from the bottom of the longest bridge the I can reach it, , but I have tried to take off other plastic bolts in other parts but to no avail
Will trix release schnabel cars again ?? (H0-scale)
by railfanwai 05/08/2018 01:57:44(UTC)
This page was generated in 0.368 seconds.
