#1 Posted : 20 April 2018 23:29:47(UTC)
I now no longer require a three way turnout but despite deleting the turnout decoder from the keyboard I appear to be unable to use these keyboard numbers for two way turnouts. I realise I am missing something here but if I delete the turnout for a two way it is then free for use. Presume it is something to do with using two numbers for a threeway. Don't have the decoder now but think it was a Viessmann.
Offline PMPeter
#2 Posted : 21 April 2018 15:55:09(UTC)
PMPeter
How did you delete it from the keyboard? Normally what I do is select a different device (signal, uncoupler, 2 way turnout, etc.) for the first address, save it and then it frees up the second address.
#3 Posted : 21 April 2018 17:56:08(UTC)
Hi Peter. I just clicked on the delete button for both numbers (wee bin I think) and presumed that was all that was needed for the keyboard numbers.
I will try what you say but it does seem an odd way to do it. Thanks for your reply.
#4 Posted : 22 April 2018 11:41:55(UTC)
Thanks Peter. Your idea worked fine. Cant think why it should be necessary though.
Offline PMPeter
#5 Posted : 22 April 2018 16:08:29(UTC)
PMPeter
I believe that for the keyboard the individual addresses need to be defined for something, even if it is just the default red and green push buttons. That is why I questioned the deletion of the 3 way turnout function without replacing it with something.
Anyway glad it worked.
Offline sudibarba
#6 Posted : 28 April 2018 03:48:54(UTC)
sudibarba
Just another fault with their software. I am getting used to it.
Eric
This page was generated in 0.265 seconds.
