Offline Trainiac
#1 Posted : 05 April 2018 20:04:08(UTC)
Trainiac
I’m thinking about purchasing a Gaugemaster HF-2 (high frequency electronic track cleaner) for my new märklin z scale layout. The layout will be controlled by two controllers and it has several block sections.
Will these block sections (controlled by a 72730 control box and 8940 signals) affect the electronic track cleaner in any way?
Erik
Mainly German trains era II-III
Collection consists of Z scale, digital H0 scale, G scale and T Gauge trains (they are sorted by collection size so my main focus is on Z scale)
Take a look at my Instagram:maerklin_z
Offline Carim
#2 Posted : 06 April 2018 11:23:52(UTC)
Carim
Hi Erik,
I don't think it should have a problem with the 72730 as I believe that they are just on/off swiches. I don't know about the signal though. What you may have to watch out for is the capacitors on feeder tracks and I am not sure what effect the device has on capacitors in the loco.s. Perhaps drop GM an email http://www.gaugemaster.com/contact.asp as they are also the main distributor for Marklin in the UK, so they should know.
Carim
Offline Trainiac
#3 Posted : 06 April 2018 12:38:14(UTC)
Trainiac
Okay thank you, I think the signal might also act as an on/off switch, so it should hopefully work
Perhaps drop GM an email as they are also the main distributor for Marklin in the UK, so they should know.
I’ll drop an email about the capacitors and post the answer here in case anyone else has this question
Erik
Offline Trainiac
#4 Posted : 06 April 2018 17:55:30(UTC)
Trainiac
Gaugemaster replied to my email and they wrote that the capacitor in the feeder track would turn off the track cleaner, and the capacitor in the locomotives will also turn off the track cleaner, but that will only happen when electrical contact is restored.
They also wrote that the 8940 semaphore might not be compatible with the track cleaner.
So the question remains if the HF-2 is compatible with block sections controlled by signals
I would also like to know what kind of power source I should get for it (the website tells me that the recommended power source is the gaugemaster M1 transformer, but the description of the M1 tells me that the M4 transformer is designed for z scale)
Erik
thanks 1 user liked this useful post by Trainiac
This page was generated in 0.366 seconds.
