Offline QQQ1970
#1 Posted : 18 March 2018 12:04:42(UTC)
QQQ1970
Advice and pics welcome.
#2 Posted : 18 March 2018 13:59:05(UTC)
I like to run mine with a train of rebuilt 6 wheelers, or alternatively "Thunderboxes".
Offline SteamNut
#3 Posted : 18 March 2018 14:18:59(UTC)
SteamNut
Any 2 axle passenger cars would work as they saw a lot of work on branch lines. I would not be surprised that a high priority freight car was added occasionally.
Offline QQQ1970
#4 Posted : 18 March 2018 14:44:13(UTC)
QQQ1970
Are 6 wheelers rebuild prone to jump tracks especially at turnouts?
#5 Posted : 18 March 2018 15:21:10(UTC)
I've never seen this happen on my layout.
#6 Posted : 18 March 2018 15:38:08(UTC)
Only at the first turnout - and only if you didn't put them on the track properly.
When you put them on the track manually then it happens quite often that the wheels of the middle axle are not properly on the rails. You'll see that on the first turnout.
Once properly on the track they work fine.
#7 Posted : 18 March 2018 16:27:40(UTC)
I usually put them on the track on a section of the layout that has an uncoupling track on it. Running the coach back and forth over the uncoupler will tell you if all the wheels are on properly!
#8 Posted : 18 March 2018 17:04:41(UTC)
I use turnouts for the test. Sometimes you'll hear a click and then the wheels are properly on the track.
This page was generated in 0.446 seconds.
