Offline applor
#1 Posted : 10 February 2018 11:50:23(UTC)
applor
Hi guys,
So I am curious to hear other members thoughts on this.
I assembled the majority of my 15 stall Faller roundhouse 2-3 years ago and I am now looking at finishing it and then painting/weathering.
Unfortunately it is now covered in a noticble amount of dust and since the roof was not attached, its all through the interior trusses etc.
I am considering what the best/easiest way would be to remove the dust.
I feel using a brush will just be blowing the dust around and also won't remove it like a rag will - but using a rag will leave missed spots in corners and be a pain in the ass to do for such a model.
I am leaning towards carefully taking it outside and using a wide mist spray on my hose and just hosing all the dust off and letting it air dry (won't take long in this weather!)
Edited by moderator 11 February 2018 06:24:40(UTC)  | Reason: Not specified
Offline Roland
#2 Posted : 10 February 2018 12:54:29(UTC)
Roland
How about taking it outside and using a compressed air can? Might do a better job than water and save having to clean up water spots later.
My Layout Build | Märklin CS3+ | K-track | Merkur | Viessmann | LDT | iTrain | Modeling primarily DB EpIV-VI
#3 Posted : 10 February 2018 13:16:01(UTC)
I would use a brush to get into the corners leaving the dust on the floor. Small vacuum can them suck that away.
Offline skeeterbuck
#4 Posted : 10 February 2018 14:37:55(UTC)
skeeterbuck
From my experience, if you want to get ALL of the dust off you need to wash it away. I would find a plastic container like a storage bin that the building will fit and fill it partially with water and some mild dishwashing detergent. Pour this over the building and use a small house painting paint brush to gently scrub all the crevasses. Then rinse the building with clear water and finally blow dry it with compressed air. I have an airbrush and use that because it's a lower pressure that can compressed air which sometimes can break off small delicate pieces. Hope this helps and good luck!
Chuck
#5 Posted : 10 February 2018 19:24:12(UTC)
Has anybody tried using one of those little USB powered vacuum cleaners that they make for cleaning keyboards and usb cameras?
I used to have one and it was pretty good at removing dust from around the pantographs on my older Maerklin models.
I have not used it on the newer ones with detachable small parts.
#6 Posted : 11 February 2018 04:17:16(UTC)
if it is only all still plastic (no posters on the walls etc.), dip it in a water bath and use a paintbrush to brush the dust off. I would not use a jet of water from a hose.
on the other hand, I find the dust on my roundhouses (after 11 years) just adds to its weathered look...
Offline Tex
#7 Posted : 11 February 2018 04:55:34(UTC)
Tex
Hi guys,
you wanted weathering and you got it! I have a two stall roundhouse that I do not remember ever cleaning and it looks fine to me . When things get dirty , which is usually after times of repair ,I use a hand held vacuum or a dry brush. The picture also shows a newly installed " my world " distance signal and a backdrop , both of which are recently installed.BigGrin
Tex
Offline PhillipL
#8 Posted : 12 February 2018 19:39:08(UTC)
PhillipL
This may sound dumb, but I have had success using damp q-tips.
Offline PMPeter
#9 Posted : 12 February 2018 20:22:56(UTC)
PMPeter
I generally use the same procedure that I would prior to painting something with an air brush. I vacuum whatever I can with a handheld Dyson. I then blow everything towards one direction with my air brush since it gives me good airflow control, and then vacuum the area I blew everything towards. That usually gives me a very clean structure to paint or weather.
Obviously if you have stains or grease spots these would need to be cleaned separately, and for that I too use Q-tips.
Offline applor
#10 Posted : 04 April 2018 08:40:09(UTC)
applor
I ended up dry brushing the outer walls and then warm soapy water brushed through all the interior and then hosed off the suds.
It then spent ~20 hours in front of a fan to ensure it dried completely to prevent mould.
It worked well for a kit of this magnitude.
#11 Posted : 04 April 2018 13:52:43(UTC)
Vacuum cleaners been around for along long time and it sucks up all the dust in the world without leaving any trace.
This page was generated in 0.502 seconds.
