Offline ShannonN
#1 Posted : 10 January 2018 07:44:58(UTC)
ShannonN
Hi everyone
I have a layout up and running at home now and want to run my Marklin 29351 Digital Starter Set VI as well as my Marklin 29074 Digital Starter Set
My layout is similar to this one. Fleischmann_HO_1.scarm (146kb) downloaded 42 time(s).
What's happening is I'm controlling them via 1 MS2, having used the auto register to add them to the MS2. Individually they run fine. That is: only 1 loco present on track at one time. However when I place both on different areas of the track they both want to run even though I have only 1 selected on MS2 .
I realize its probably just a case of them using the same address for control but my main question is with auto registration shouldn't address conflicts be impossible?
Any guide to do manual registration on MS2 to keep them totally separate?
Blessings Shannon
#2 Posted : 10 January 2018 08:02:56(UTC)
Loco addresses are unique per serial number - and every mfx decoder should have a unique serial number.
I had two mfx decoders with the same serial number (0xffffffff in my case) and the MS2 could not tell them apart and could not control them individually.
I returned the decoders to Märklin to have them swapped. This solved my problem.
The MS2 cannot display the serial number of a decoder, so further analysis with the MS2 is difficult.
A CS2 will display the mfx address (or at least a pseudo mfx address). Maybe you know any CS2 owners you can visit for a test ...
If you reset the MS2, register the first loco, then register the second loco, do you get two entries in this case or just one loco entry?
Manual registration is only possible if you disable mfx - either in the decoder (most likely impossible) or in the controller (applies to all locos). Then you can control the locos using MM protocol or may DCC protocol (if supported by the decoder - DCC is not listed for those starter sets).
Offline ShannonN
#3 Posted : 10 January 2018 08:44:19(UTC)
ShannonN
I did that, the controller was the one I got with the Benelux 2nd hand starter kit it already had the loco registered so I deleted it then one by one registered both I do get two separate icons and feature sets this is where I'm getting stressed. I may try it with my other MS2 its the later black one
Blessings Shanny
#4 Posted : 10 January 2018 15:37:22(UTC)
Try to use the new MS2. If not, you probably need to update the database in your original MS2, as probably one of the loks is not recognized individually.
Did the MS2 recognize both as MFX, if not, it may have defaulted to DCC where each lok might have the address 3, or to Motorola MM protocols.
Normally, when a mfx locmotive is recognized, it displays the Maerklin given lok name and information for each lok. That itself should prevent two loks from responding to the same commands.
I still wish Maerklin would have come up with an updated 6021 controller that you have worked with MM/MFX/DCC and had 28 functions and 3 digit addresses.
I would prefer to be able to key in the address rather than having to scroll to locate the one that I want to control.
Offline ShannonN
#5 Posted : 10 January 2018 16:40:35(UTC)
ShannonN
Hi Mike
will try that tomorrow The MS2 does id both as MFX with Marklin icons to suit. the icon looks ok to me that is; the steam loco shows a steam loco and the electric shows an electric icon
Cheers Shanny
Offline TEEWolf
#6 Posted : 10 January 2018 16:44:25(UTC)
Hi everyone
Blessings Shannon
Shannon,
if you do not set the speed to ZERO for the first running loco before you set your second one on the layout, the first loco will always run further with its last speed you have setted up.
It is one function of the MS 2 that you may run up to 11 locos parallel at the same time, but you only can control always one loco. If you want to control another one, you have to switch to the entry for this loco and alter whatever you want (here the speed).
If you want to control 2 runnig locos separately with more different speeds, you need 2 MS 2. These 2 you can attach easily to your digital starter box. To attach more MS 2 to your layout? It is possible with art# 60122 (MS II Hub for distribution device). It is a hub for adding more MS 2 controllers to your layout. And with each MS 2 you control always one loco.
Märklin offers for the MS 2 art#60653 a technicel tipp (TT) #306
https://www.maerklin.de/...faq/Technik-Tipp-306.pdf
there it is only in German available here a good translating software
https://www.deepl.com/translator
What I tried to explain to you, you will find the description by Maerklin in the TT #306 page 4 under the heading "Loks fahren" (= driving locos or better controlling locos).
Offline Bones
#7 Posted : 26 January 2018 13:30:15(UTC)
Bones
Just a little tip I have found with my MS2
Also when you put a new loco in make sure no other locos are sitting on any live part of the track
Make sure you turn all the locomotives of before you take them of the track
Turn each of the running loco's off before you add a new loco because the memory of the MS2 will
automatically start any previously added loco's off at the old settings from your previous runs
I now have five loco's that run very well now and 3 are mfx and 2 are Ecos
ThumpUp
Offline TEEWolf
#8 Posted : 26 January 2018 23:46:14(UTC)
Yes, but only you are programming and/or adding it in your MS2 database - if the new loco is not yet listed there. But this you may do on a seperate, from your layout completly disconnected track, the so called pogramming track.
Well I always set the speed to zero, if I change to another loco out of my registered loco fund.
Turn each of the running loco's off before you add a new loco because the memory of the MS2 will automatically start any previously added loco's off at the old settings from your previous runs
Well it is less a memory than more a staying at the last set up position.
ThumpUp
Set up the 3 mfx locos causes you no problems. Also you do not need to program them first with your MS2. You set it on the tracks of your layout. The mfx decoder recognize it and register the locos automatically. It may last a few seconds till the registration will start or perhaps you have to move them very short and softly on the tracks till it gets the contact to the tracks. Very often are either the tracks dirty or the wheels of your locos. Dirty wheels is a major problem for not getting contact between the tracks and the loco.
But what do you mean with ECoS? ECoS for me is not a decoder inside a loco, it is the controller from the German company ESU and a equivalent to a CS 3 from Maerklin, but not for a MS 2. A MS 2 controller is much smaller than an ECoS or CS 3, as far as I know, because I only do have MS 2 and CS 3 controllers in use.
The 2 locos which has not a mfx decoder you have to register first. It depends which decoder these locos have inside. By this decoder you may programm them in fx, MM2 or DCC format. The MS 2 understands all these formats.
You did not write which MS 2 you got. There are the #60653 (grey) and #60657 (black). The 60657 has only another colour which aligns it with Maerklins new CS 3. But both MS 2 are technically identic. Even they are technically identic with the version from TRIX (#66955).
If you need a manual for the MS 2 you find it on Maerklin's homepage
https://www.maerklin.de/...s/details/article/60657/
and Maerklin issued special technical tips for various topics. One tip is for the MS 2
Technical Tip #306 is for operating a MS 2. These tips are unfortunately only in German available. But here you find a good translation programm.
I think it is better than the Google translator.
There are massive articles published about a MS 2, but 95% I guess are in German. Even Maerklin does so. Here another article from Maerklin about programming wth a MS 2
https://www.maerklin.de/...4_Digital_MM_2014_03.pdf
Have fun
#9 Posted : 27 January 2018 08:44:35(UTC)
LOL
Many threads on this site - including this thread - discuss problems with automatic mfx registration.
For Shannon it does not work as it should. Explaining how it should work may not do much good for him.
BTW: When registering a new loco, there can be any number of locos on the track.
Find loco can only work for MM or DCC locos if there is just one loco on the track.
Programming should only be done with just one loco on the track.
This page was generated in 0.578 seconds.
