Offline Thewolf
#1 Posted : 21 January 2018 10:42:28(UTC)
Thewolf
Hi everyone
For various reasons, I never had the opportunity to use the CS2 in the fund of its possibilities as I never had the opportunity to use all the functions of the locos.
Since a few months, I'm back in the world of the train.
In all the functions of the locos, there is one with which I have difficulties : Sound of squealing brakes off
Already the word ''off'' For me the word '' OFF '' means that the sound of the brakes will not work. So if I press the sign, the sound does not work.
I also suppose that there is a relationship between the sound of the brakes and the braking delay.
As braking delay = small number less delay before stopping, which means for me the more the number is small the more the braking is intense, so the more the sound is loud
I did a little test with a loco yesterday : nothing...I have the impression that the loco must be in "automatic" mode for the sound to work. I also feel that the manual control of the
speed by the control button of the cs2 does not cause the sound of the brakes
Thank you for your replies
Thewolf
Offline Gregor
#2 Posted : 21 January 2018 10:54:10(UTC)
Gregor
I found that when you set the braking delay below a certain value (so a fast deceleration), the squeeling sound does not play at all, regardless of the setting of the "SQUEELING SOUND OFF" function.
If you want to hear your trains squeel, you need to set braking delay higher then 3.
This value will differ per train.
Gregor
Edited by user 22 January 2018 12:45:25(UTC)  | Reason: Spelling mistake corrected
#3 Posted : 21 January 2018 12:43:20(UTC)
I have found it varies with different locos. Just a matter of trying different settings until you get the right sound you want. Also appears to work better when slowing from faster speeds.
Offline Thewolf
#4 Posted : 21 January 2018 13:50:27(UTC)
Thewolf
ok...ok..but one of my concerns is if the brake sound also works with the control button of the cs2 when the speed is decreased slowly with this button?
Because in the test yesterday the cv of the braking delay was 10 then 12 then 15 and nothing at all. I might have gone to 20
The loco is 36430 marklin
Thewolf
Offline Gregor
#5 Posted : 22 January 2018 12:41:27(UTC)
Gregor
I believe the squeeling will only appear after a reasonably fast deceleration, and only in the last moments before standstill.
So no squeeling when slowly going down a few speed steps.
Gregor
Offline PMPeter
#6 Posted : 22 January 2018 16:22:44(UTC)
PMPeter
For a test, with your loco running at a fairly fast speed go to the control screen of your CS2 and use your pointer, mouse or whatever you use on the touch screen, and point at the O speed for the loco. This should cause a fast stop and the brake squeal. If you don't get a squeal with this approach then there is something else that needs to be checked or set.
Offline Thewolf
#7 Posted : 22 January 2018 16:43:26(UTC)
Thewolf
PMPeter thanks..This is an excellent suggestion
Thewolf
This page was generated in 0.394 seconds.
