Offline Thewolf
#1 Posted : 14 January 2018 01:51:05(UTC)
Thewolf
Hi guys BigGrin
I must change the values of certains cv for all decoders for all locos in CS2.
Maximum and minimum speed, because the speed calibrations of locos is crazy. I use Itrain and the calibration is a disaster.
The last landing does not inform the maximal speed, and the gradual scale(ladder) of speeds..i'd rather sayBlink
For example, the landing 126 for b29 (a belgian steam loco..not the airplane) informs a 27 km / hour speed. The maximum speed is 100 km/h. The maximun speed of this loco : 30 km/h. I want 100
Another example is série 57 sncb , the landing 126 for this loco informs 200 km/h, maximum speed is 120 km/h. This loco is crazy when she runs at maximun spped
I have never made changes in the values of the decoders of my locos...but I got a problem with the decoders : they are not well configurated. That what Is I think. I am not a specialist.
So what can I do for the changes of values in cs2?
I searched on you tube for a tutorial in video ? nothing Cursing
Thank you for your reply
Thewolf
#2 Posted : 14 January 2018 05:23:01(UTC)
I never manage to change values with my CS2,i am still using my 6021.Always trusty and beloved.The answer i always have from the CS2 is "the parameters are allready transfered to the locomotive" but any parameter have never transfered ,so the 6021 always help me..BigGrin
#3 Posted : 14 January 2018 08:09:42(UTC)
I don't make videos.
The GUI for changing CVs in the CS2 is not really user-friendly and somewhat counter-intuitive, but it works.
And if you tell us how far you get and what you do not understand, someone here will answer your questions.
Offline Thewolf
#4 Posted : 14 January 2018 08:45:24(UTC)
Thewolf
Thus if I understand well nobody can help me to solve my problem of changes of the values of speed of the decoder of locos?Blink Crying
Thus after more than 25 years and I am 63 years old ...I will have to change hobby .. OK ... am going to put an announcement to resell everything: 25 000 Canadian $
Am going to speak about my offer of sale to my dealer Mike .
That's a joke BigGrin
If memory serves me well, I think that Itrain planned of what to make these changes I am going to go to consult the manual...I have forgotten this way.
Ostie que je vieilis !!!!!!!!!!!!
Thewolf
Offline Danlake
#5 Posted : 14 January 2018 09:26:44(UTC)
Danlake
Hi Teewolf,
Søren who is also a member here has made a few videos.
Check his very informative website here: http://railway.zone/post...-and-decoder-programming
Regarding your problems my suggestion is:
1. Identify what decoder is fitted in the locos
2. Get hold of the manual
3. Put the loco on the programming track
4. Reset the decoder by writing value 8 in CV8
5. Perform a test drive and verify max speed
6. Try changing CV value for max speed and check if it made a difference?
Sometimes you can have issues with max speed if you have configured the motor control reference voltage (CV 53) seperately, so best to try a reset first and then test drive the loco.
Brgds Lasse
#6 Posted : 14 January 2018 09:37:35(UTC)
When i read locomotives manual it stand about value of the CV:
CV1 to change the adress
CV3 to change acc
CV4 to change brake
CV5 to change maximum speed
CV8 to reset decoder
CV50 to choice protocol
CV63 to adjust volume
Those CV adresses are standard but there is more to use and you find it at Märklins homepage by download sound decoder manuals.
When i use DCC protocol with the locomotive it can use either 28 or 126 speed steps.
Maybe yours locomotive do have wrong speed step?
Then in case you have to check it at CV 29 and see if the values is correct?
Both MM and DCC do have same default.
If nothing happens try to reset decoder.
Check also after CS2 if it stand correct speed step by use DCC protocol.
If you use DCC protocol you must check if that speed step stand 28/126 in the CS2.
Offline Thewolf
#7 Posted : 14 January 2018 09:49:11(UTC)
Thewolf
Danlake and Goofy BigGrin
Thank you a lot both BigGrin
Really very appreciated Cool
But it is going to need that I am very careful ...I am not an expert in these things... I have never made it
Give me a balance sheet of company and I am going to explain what is wrong...but a Marklin loco decoder and the value of Cv, ....It is the language which comes from the space
Thewolf
#8 Posted : 14 January 2018 10:30:21(UTC)
Those CVs are not standard. Not all decoders use CV 8 for reset, that CV 50 is only Märklin standard, CV 63 is ESU standard, but adopted by Märklin.
And even CVs 2 through 6 are used differently from brand to brand.
CV 1 is really standardised.
Always make sure you use the correct CV list to avoid problems.
No, they don't.
Offline Thewolf
#9 Posted : 14 January 2018 11:51:57(UTC)
Thewolf
No, they don't.
Ok Tom..but I am sorry ,,,you don't explain how to do
By reading your answers, I do not move forward...
At least with Goofy and Danlake I move forward
When you wrote this : '' And if you tell us how far you get and what you do not understand, someone here will answer your questions.''...ok but how to do for reading what the cs2 informs like values of cv ?? You don't explain Blink
I had said that I believed that ''Itrain''' could find me the solution to my problem.
I had forgotten the advantage that got Itrain to change the cv of the decoders of locos.
Decoder Programming
Every decoder has a set of configuration variables (for DCC) or parameters (for Selectrix)
that define its behavior. One simple example is the address of the decoder, but there are
also more difficult settings. A lot of tools are available, sometimes from the supplier of the
decoder itself, to assist you in configuring your decoder exactly as you would like.
This feature in iTrain is not here to replace all other tools. It is meant as a basic
programming tool for the common settings available in most DCC and SX2 decoders20
without having to disconnect the interface in iTrain. This can be very helpful when you
want to program the decoders on the main layout (PoM)21 instead of on a service track.
Configuration
The first step in programming a decoder is specifying the configuration. It is possible to
specify the configuration for a locomotive, a wagon or an accessory. In this example the
locomotive will be used as this is the most common target for programming decoders.
In the properties of the locomotive there is a tab ‘Configuration’ with a table. In this table
possible CV or parameter numbers are available. You have to define which numbers are
used to store a value in the decoder (by checking it) and what the type of the value is (by
double clicking it and selecting it from a list). Additionally you can enter a description in
your own words. It is not necessary to fill in the column ‘Value’ at this time, but if you know
the value already it is recommended entering it directly so you need no other
administration for that anymore.
Values are always stored internally as decimal values, but depending on the type they will
be displayed in another format if that makes it easier to interpret them (for example the
vendor is translated into a name). You can always use the tooltip to see it as a decimal,
binary, or hexadecimal value or an ascii character. Entering a value in the column is by
default always a decimal value, unless you prefix the value with a ‘b’ for a bitmask,
‘h’,‘x’,’#’ or ‘$’ for hex or a quote for a character (so ‘A’ is the same as 65).
It is a lot of work to define the configuration for every locomotive
again. By using the popup menu of the table you can make that
more comfortable by copying & pasting definitions of other
locomotives. Select the rows you want to copy and paste them in
another configuration with the same numbers. There are also a
few basic templates for the most common variables/parameters
for DCC and SX2 to get you started quickly.22
Programming tool23
If you have defined a configuration for a locomotive, wagon or
accessory and iTrain supports programming with your interface (command station or
programming hardware), you can actually read/write values via the programming tool in
iTrain. This tool can be found in the menu ‘View’ -> ‘Decoder Programming’. There you
have to select the type of object you want to program via a submenu. We will explain the
‘Locomotive’, but programming the other objects works in a similar way.
It allows you to see that it is possible to work with Itrain for the necessary change of the values of the decoder for a perfect calibration of speeds
I quickly read and ...my god ...Crying Crying Crying Confused Confused Confused . that it looks complicated.... It is complicated...I do not understand the Chinese
Thewolf
#10 Posted : 14 January 2018 11:58:07(UTC)
No, they don't.
Yes they do!
Both MM and DCC stand default 6 when you buy sound decoder in the CV 29.
I did wrote this adress in the topic number 6.
#11 Posted : 14 January 2018 12:04:45(UTC)
Now you start problem by avoid to use CV adress present by of Märklin and it doesn´t matter what manefacture do present CV adress.
The good point is to follow CV adresses by adjust them.
#12 Posted : 14 January 2018 13:01:52(UTC)
OK, maybe I should shut up.
Goofy explains it so well and he knows everything better than I do anyway.
It looks as if iTrain makes CV programming even more complicated than the CS2 does.
Do you have an MS2? The CV programming screens on the MS2 are much simpler with less distraction and less confusion.
Offline Thewolf
#13 Posted : 14 January 2018 13:30:52(UTC)
Thewolf
Tom,
''OK, maybe I should shut up.''
I undoubtedly badly expressed myself, Don't forget : english is not my native language.
What I meant to say is : you do not explain to make enough how.
I consider you as a specialist but sometimes your explanations are not enough retailed and I have the impression to be blocked
''It looks as if iTrain makes CV programming even more complicated than the CS2 does.
Do you have an MS2? The CV programming screens on the MS2 are much simpler with less distraction and less confusion''
About Itrain, I am verifying the whole . But I am certain that with the support of the forum Itrain and Xander the creator, it will not be difficult to make
No MS2 for me. It would be can be a solution to buy a MS2 if it is still possible to do it and not too expensive. I like this advice. Maybe i wrote BigGrin
#14 Posted : 14 January 2018 13:54:27(UTC)
There are different aspects:
  • The concept of CV programming with DCC
  • CV programming for DCC decoders with the CS2
  • CV programming with iTrain
The thread title is about CS2, the text you quoted is about iTrain.
English is not my native language either. Sometimes I have a loss for words, especially when it comes to detailed explanations in non-technical terms.
Is the concept of CV programming clear?
Do you want to use the CS2 directly or via iTrain?
Offline Thewolf
#15 Posted : 14 January 2018 16:12:23(UTC)
Thewolf
I understand that the title which I used is misleading, especially if I speak about Itrain.
Is the concept of CV programming clear? My reply is no
Do you want to use the CS2 directly or via iTrain? My reply is :
Use CS2 worries me
Use Itrain worries me too
Between both solutions really I don't know
There is also a solution of the MS2, which according to what you said would be better...I made a search on EBay ... too expensive
Thewolf
Offline Thewolf
#16 Posted : 14 January 2018 17:34:47(UTC)
Thewolf
The version of Itrain which I use for the moment does not allow me to program decoders.
I need the version above.
To buy a MS2 will cost me two and a half times the price of the superior version of Itrain.
I think that I am going to use Itrain for the operation of the changes....although with me you never can tell ....in 2 days I can change method
Thewolf
Offline Danlake
#17 Posted : 14 January 2018 20:04:11(UTC)
Danlake
Hi Thewolf,
Let us know a few loco (article numbers) of what you would like to adjust the basic settings on, then we can try and assist you.
Iam pretty sure Itain will not be able to program most Marklin decoders, only those that have built in DCC compatibility, which is a minority.
So pretty sure you are better of learning and using the CS2 for this.
Brgds Lasse
Offline Thewolf
#18 Posted : 14 January 2018 20:51:31(UTC)
Thewolf
Hi Thewolf,
Brgds Lasse
Ok Danlake Cool
There are 4 locos, 3 with MFX + digital and 1 with MFX digital.
I saw it on the site marklin.
I don't know the difference with MFX + digital and MFX digital : maybe the steps of speed ( 28 or 128 ?)
The locos : with MFX + digital : 37220, 39095 37206
with MFX digital : 37851
Thank you
Offline Danlake
#19 Posted : 14 January 2018 21:38:09(UTC)
Danlake
Hi TeeWolf,
As all your locomotives are Mfx there should be no need to use CV for changing the settings like min, max speed etc.
Have a look at English manual page 48.
Try first to press the button reset while the loco is on the programming track?
Then noted down what the new setting for max delay is (means max speed).
Then try and change the this setting by e.g. entering value 120 and see if that made it slower. Play around till you find the value you want for max speed.
Below link to an English manual
https://www.rocousa.com/MARKLIN/60215_cs_gb.pdf
Brgds Lasse
Offline Thewolf
#20 Posted : 14 January 2018 22:02:15(UTC)
Thewolf
Thank you very much DanlakeBigGrin
Really very appreciatedCool
But for this sunday...trains are closed BigGrin
I shall see tomorrow
3 Barclays League soccer games to watch with Belgian players...important before the world cupLove Love
Thewolf
Offline Thewolf
#21 Posted : 15 January 2018 13:04:03(UTC)
Thewolf
Hi everyone Cool
When Danlake wrote :
''Iam pretty sure Itain will not be able to program most Marklin decoders, only those that have built in DCC compatibility, which is a minority.
.'' he is right
This morning on the forum Itrain I received important information.
About the decoder programming by Itrain. Itrain allows only DCC decoders not MFX marklin
Please see :
Re: Decoder programming
Report this post Quote
Post by xanderb » Today, 05:20
Yes, but it only works for DCC and not for MFX locs, as this is proprietary for Märklin and not open.
Post by HCCm » 32 minutes ago
No.
Marklin is changing to build in DCC in their decoders, but this will happen slowly is my experience from the past.
When I had an IB, the manufacturer of that device publised procedures for the IB how to programme M. decoders. M never did.
Post by xanderb » 31 minutes ago
MFX is a proprietary protocol for which their is no official documentation (the same for Motorola). Programming MFX-decoders is only possible with Märklin devices. DCC is from Lenz, is completely open, standardised and open. It can be used by anyone.
Yes, I was born and raised with Märklin, but as a hardware and/or software developer it is much easier to adopt DCC. That is why most command stations have DCC and only some have MFX. But the 2-rail part of Märklin called Trix also uses DCC and so Märklin will support both in new decoders so they can be used in both, but that is only recently.
Xander Berkhout (10)
Developer of iTrain
To see you later
Thewolf
Offline Thewolf
#22 Posted : 15 January 2018 21:11:37(UTC)
Thewolf
Hi everyone BigGrin
Today here is 2-3 hours I followed what Danlake had advised me
I did a reset of the decoder of a loco
Here two photos ;
The first picture is the inside of the cv of the loco...after the reset of the loco
The second picture is what appears when we open the ‘’ tool ‘’ of the loco
On the second picture the tools with which I have to work for a graduation of speeds
But...on the second picture below the CV 5 appears a line +/67-94 board of speed...I suppose that it is about speed calibration...but I would like to have details on +/67-94, what it means
I suppose that I have to calibrate speeds maximum and minimum for a good calibration of speed
Thewolf
#23 Posted : 15 January 2018 22:51:39(UTC)
Have you actually tried clicking/tapping on the graph icon !!! ?
Offline Thewolf
#24 Posted : 15 January 2018 22:55:36(UTC)
Thewolf
Peter,
No...I waited the replies
Thewolf
Offline Thewolf
#25 Posted : 15 January 2018 23:34:34(UTC)
Thewolf
I did it Cool
A graplic appears with a choice of options ( linear, etc,,,)
Also touches + and - with 34 to the left and 175 to the right I think
I don't know what are the good values to register
Thewolf
Offline Danlake
#26 Posted : 15 January 2018 23:58:05(UTC)
Danlake
Hi TheWolf,
Don’t worry about the speed curve for now. I suggest to use the standard curve which the decoder is fitted with.
Use the menu (from your second photo) to adjust min, max speed and acceleration and braking delay.
For braking delay make sure you put it to a shorter value, because you want the PC software to brake your loco and if you keep it too high value it won’t be able to brake accordingly in short blocks.
Max speed is just what you are comfortable with on the layout. Min speed should be a smooth crawling speed.
After this then try and do a new speed profiling in Itrain and remember if you subsequent change anything on the decoder regarding motor performance you have to do a new speed profiling in I train.
Brgds Lasse
Offline Thewolf
#27 Posted : 16 January 2018 17:30:53(UTC)
Thewolf
Hi guys Cool
Hi Danlake Cool
Before starting the speed calibration, I would like to understand the meaning of the values recorded in the acceleration and braking delay.
In both cases, what does the smallest number mean? the biggest?
What is the impact on the loco? The more I go down, the more ...?
The more I increase, the more ... ??
Sorry to ask these questions, but I want to understand
Thank you for your replies
Thewolf
Offline Danlake
#28 Posted : 16 January 2018 19:39:52(UTC)
Danlake
Hi TheWolf,
Braking and acceleration delay is the time it takes from full speed to stop and vice versus (in theory). Of course a loco that moves fast will use a longer distance to stop versus a loco that moves slow (with the same braking value).
The most common standard used is that the delay is the value x 0.25.
So the higher number you set the longer time it will take to brake or accelerate.
For my locos I normally have around 12-20 for braking delay and around 30 for acceleration.
Many PC software users will use a braking delay of absolutely minimum, but sometimes I run my train just with the CS and prefer not to have to abruptly stoppage of the loco (to protect the gears etc.).
Brgds Lasse
Offline Thewolf
#29 Posted : 16 January 2018 19:50:10(UTC)
Thewolf
Hi TheWolf,
Brgds Lasse
Thank you Brgds Cool
I suppose that Brgds is your little name , no ? And Lasse your name of family ?
And all these parameters will vary depending on whether the loco is a steam, an electric or a diesel.
What fun and time to spend for a retiree...and most of all ... peace for my wifeWoot RollEyes Razz
Thank you again Brgds
Thewolf
Offline Danlake
#30 Posted : 16 January 2018 20:07:32(UTC)
Danlake
He, he - yes my first name is Lasse and Brgds is just short for Best RegardsBigGrin
Offline Thewolf
#31 Posted : 16 January 2018 20:48:41(UTC)
Thewolf
Sorry..I did not know
As we say in my native country ..hé meeerrrde me suis gourré BigGrin LOL Flapper
Thewolf
Offline Thewolf
#32 Posted : 17 January 2018 01:48:29(UTC)
Thewolf
Hi guysCool
I did one speed calibration....The results of the curve do not please me.Crying
The step does not inform the maximum speed of the locomotive .
I correctly made the recordings of the values - minimum and maximum speed... the first time maximunn speed at step 126 : 88 km /h. Yhe second time 89 km/h...the speed O at the step 5- step 6 1, 7 km/h
Minimun spped recorded at the CV value ; 5 km/h
Maximum speed : 120 km/h
I don't understant why the last step of the speed curve does not inform the maximun speed that the loco normally has to reach
To see again tomorrow
Thewolf
Offline Danlake
#33 Posted : 17 January 2018 02:39:09(UTC)
Danlake
Hi TheWolf,
When you write speed calibration I assume you mean what you did in the Itrain software?
And this is where you got the corresponding speed for various speed step?
To be able to assist. Are you happy now with the configuration you did with your CS and now the issue is how to get a good speed profiling in Itrain?
A normal speed profiling should give something like an exponential graph - I.e. as the loco builds up speed it accelerate faster and faster.
When configuring my loco I always do max speed based on a stop watch and a circuit around my layout (actual track length you can get from the track planning softwares). When I am happy with the performance of the loco just running with CS I then start the speed profiling in my PC software. I normally get within +/-5 km/h between my stopwatch and the PC software.
Brgds Lasse
Offline Thewolf
#34 Posted : 17 January 2018 11:32:43(UTC)
Thewolf
Hi TheWolf,
Brgds Lasse
Hi Lasse
'' When you write speed calibration I assume you mean what you did in the Itrain software?
And this is where you got the corresponding speed for various speed step?'' this is exactly what I want to explain
Here you wrote :'' When configuring my loco I always do max speed based on a stop watch and a circuit around my layout (actual track length you can get from the track planning softwares)'' since I am in digital (2012 and when I lived in my native country it was analog) I never did that..nobody explained it to me ... but I never asked the question
I had an idea this morning ... I'm not sure it's good ... but I can try it...
Here is my idea :
I have the impression that even if the speedmeter of the cs2 informs a maximum speed of 130 km / h, the loco does not run at this speed, but at a lower speed, like 90 km / h for example.
My idea :
1- to control the speed by Itrain ...
2- to record the maximum speed on CV5 ...
3-to do a speed calibration by Itrain ...
4- and when Itrain's graphic will inform me in step 126 the maximum speed ... register this value in C5
I am in digital and I have Itrain since 2012 ... I could not deepen this method and Itrain (health-transplant problems)... but in great shape for several months ... good time to catch up
Have a nice day Lasse
Thewolf
Offline Danlake
#35 Posted : 17 January 2018 20:28:19(UTC)
Danlake
Hi TheWolf,
The speedometer on CS2 has no relation to the actual max speed.
This is only for visual representation and you can enter what ever value you would like. Try writing 10 km/t and you will find the loco will still go to same max speed as before.
Here is what you need to do:
1. Configure your max, min, acceleration and braking delay using the CS2 menu
2. Once happy with how the loco feels, then try and measure a straight distance on the layout and time it when the loco travel full speed.
3. Loco speed is = distance divided by time x 87
4. Enter this max speed for the speedometer.
5. Open Itrain and then to the speed profiling/calibration.
Once you have done the speed profiling in Itrain you may get a more accurate calculation for max speed. If it differs a lot from your initial calculation then change the speedometer, but don’t change any CV values.
Hope this helps and best of luckThumpUp
Brgds Lasse
Offline Thewolf
#36 Posted : 17 January 2018 21:35:25(UTC)
Thewolf
Hi TheWolf,
Brgds Lasse
Hello Lasse
I did not read your last comment ... I was busy in another room ... I did what i wrote this morning or yesterday evening and here are the results of the tests I did this morning:
Loco: 37851
decoder resets
all the original CVs
Cv 3 15 (acceleration)
CV 4 15 (brake)
Cv 2 17 (min speed0
Cv 5 255 (max speed)
The graphics (itrain)
(1)
(2)
(3)
It seems to me that the last steps in the curve are weird
While waiting for your comments I will re-read your last post and I will certainly have questions to ask on this one
To see you later
Offline Thewolf
#37 Posted : 17 January 2018 21:53:04(UTC)
Thewolf
good ... good ... time ...Lasse BigGrin .... you're going to laugh ... my wife and I have no watch Blink ... since ... my god ,, I do not know ... it'll be difficult to do this job with computer time or the grandfather clock ... or digital kitchen clocks
I think I will have to work with Itrain ... by lowering the CV 5 values until I reach the max speed I want
I would like to leave the values CV 3 and 4 as they are ... and reduce the minimum speed to 10 (CV2) a bit ... and not to touch it again if it works
What do you think ?
As for the incorrect form in the last steps of the curve, I do not know what to do. Is it so important?
Thewolf
Offline Thewolf
#38 Posted : 17 January 2018 23:50:14(UTC)
Thewolf
Hi guys ...Hi Lasse
I like the latest speed calibration for the 37851 I made
The curve is more beautiful ... except the last 2-3 steps
Cv values of the cs2 :
Cv 3 10
Cv 4 10
Cv 2 10
Cv 5 150
Maximum speed itrain : forward speed : 99,6 km/h
rear speed: 105.7 km/h
About the speed of locos, the speeds at which I want my locos to run are the actual speeds of the locos, which I found while doing research on wikipedia
I know that some members of this forum will not like it, that the speeds will appear too slow, but my layout is not a reproduction in Ho of the circuit Gilles Villeneuve
If so, I would have bought a Carrera or Scalectrix
(4)
(5)
(6)
Lasse and of course all the others members, what do you think ?
Thewolf
Offline Danlake
#39 Posted : 18 January 2018 04:57:59(UTC)
Danlake
Hi TheWolf,
Iam not to familiar with Itrain and had to download the latest English version.
Agree that that first few graphs does not like optimal.
First off I think your measured distance is too short (only 22cm)?
I would recommend at min 1m but preferable around 2m. Any tiny inaccuracy in when the feedback gets activated and report to PC software or any small motor performance issue will of course be magnified 10 times when using a very short measurement distance.
Secondly Iam not sure I understand fully the concept of the red and green graph line. Is one line the theoretical values Itrain calculated before you started the speed profiling? And the other line represent the actual represent?
Also try and maximise your window, that should make the graph much more wider and smoother (in the manual the windows are much bigger and the graphs looks more normal than a very steep curve in your print screenshot).
I noticed you also put max speed 255 in Itrain in the calibration window. 255 is a numerical CV value and has nothing to do with the actual speed. You may have a large jump towards the end as you are trying to do a speed calibration on a number the loco can’t drive?
Once you have the actual max speed, as calculated by Itrain, then enter the value and try and do a new speed calibration.
In this thread you can see a photo of a typical speed profiling curve with Traincontroller.
http://modelersforum.com...rs/abendstern-nebenbahn/
Brgds Lasse
PS: Any mobile phones, even old Nokia has a stop watchThumpUp
Offline Thewolf
#40 Posted : 18 January 2018 13:21:58(UTC)
Thewolf
Hi LasseCool
I will answer in more detail later ... but first of all I do not have a mobile phone ... my wife and I consider it a useless gadget and too expensive for what it can bring us ... we prefer to read a good book in the subway rather than pounding on a mobile phone.
Last week at the restaurant we saw 5 couples with tennagers..parents talk together...teenagers looking at a mobile phone ... tapping on a small keyboard ... and forget to talk ... not for us and I'm not talking about the use of this gadget in front of a car ... to ban as soon as possible
Thewolf
Edited by user 18 January 2018 21:09:34(UTC)  | Reason: Not specified
Offline Thewolf
#41 Posted : 18 January 2018 14:39:17(UTC)
Thewolf
Hi TheWolf,
Brgds Lasse
LasseCool
I am pleased to provide you with some clarifications
22 cm is not the measured distance but the length of the loco
The calibration of the speed with Itrain is calculated over a distance determined by two points of contact ... in my case over a distance of 81 cm determined by C30 of one edge and C31 of the other
Here :
I add that according to the forum Itrain the length of the portion for the calculation of the calibration has no impact
Here :
This is an example of a member of the forum :
Length between contacts: 14.9 cm
See the curve
I understand that entering 255 in the maximum speed box may suggest that it is the speed of the CV that I indicated ... but it is an example ... in the second test I indicated maximum speed 150
The red and green lines represent the forward and reverse curves. With Itrain we have the choice, either a direction of travel, forward or two directions forward and backward for the calculation of the speed calibration
For the shape of the curve and compared to TrainController it seems to me that we must not forget that they are two different software
Moreover the curve of the example (14.9 cm) is not better I think
I will ask the designer of Itrain if the curve of my loco tested is correct
To finish I must think about how I see the maximum speeds of locos on my layout.
Let me explain: for example the steamer BR 95 00
According to wikipedia this loco had a maximum speed of 65 km / h
On my layout at 65 km / h it will give the impression of not driving
To think about and get away with other members...or better: do some tests
Have a nice day
Thewolf
Edited by user 19 January 2018 00:44:31(UTC)  | Reason: Not specified
Offline Thewolf
#42 Posted : 18 January 2018 15:13:10(UTC)
Thewolf
I forgot
the expanded version of speed calibration
Offline Danlake
#43 Posted : 19 January 2018 00:48:53(UTC)
Danlake
Hi TheWolf,
Thanks for clarifying regarding Itrain and speed calibration.
The curve included in your last post looks perfectly normally to me?
Regarding prototypical speed. I also try and keep my loco at the protypical scale speed. However for slow mowing streamers and diesel shunters I normal add a bit extra (10-20 km/t).
Brgds Lasse
Offline Thewolf
#44 Posted : 19 January 2018 12:19:02(UTC)
Thewolf
Hi TheWolf,
Brgds Lasse
Hi Lasse Cool
I'm happy to read your last comment about the curve.
As they sais in my hometown, '' j'ai cravaché '' , literally in English I whipped
About the speed, this is exactly what I am going to do
Lasse I really appreciated your help ... I had long suspected that you were a specialist Marklin world and Ho in general ... as there are a few here ... certainly not me
Now I will continue the speed calibration of my 30 locos ... and I have not finished configuring Itrain yet ....
but I feel that another problem will be on the horizon: the good way to make the feedback with the s88 .... the reliability of the 24994 and others ... the reliability of the magnets with reed ... I am skeptical ... but for now it works
Lasse thank you again
Have a nice day
Thewolf
#45 Posted : 20 January 2018 08:43:28(UTC)
The note about change of the values of CV adress in the CS2.
Offline Thewolf
#46 Posted : 20 January 2018 12:54:20(UTC)
Thewolf
Please can you explain? I do not like riddles
Thewolf
Guest (4)
This page was generated in 1.022 seconds.
