Offline Albert Lind
#1 Posted : 31 December 2017 23:54:09(UTC)
Albert Lind
Can Marklin 3-rail M track be successfully laid on 1" or 2" rigid foam insulation board (pink or blue)? If so, will track screws hold in the rigid foam insulation board? Thanks.BigGrin
#2 Posted : 01 January 2018 00:34:21(UTC)
I haven't tried this, but I don't know if it would hold permanently. Maybe hot glue might be a better option.
I'm sure you could lay the track OK, but the fixing might be an issue.
Offline dominator
#3 Posted : 01 January 2018 05:16:16(UTC)
dominator
I have used a product called Pinex and then used longer screws into the 1/2" plywood below. Still quieter than straight onto plywood. It does make the track too rigid and more work if a piece of track needs replacing. You could buy longer screws and nuts and use that combination in your case. In my next project I am considering using corrugated cardboard on top of the 9 mm plywood.
Dereck
Edited at: by user 01 January 2018 10:36:08(UTC)  | Reason: Not specified
Offline Michael4
#4 Posted : 01 January 2018 10:31:08(UTC)
Michael4
I thought about insulation board but in the end decided to use 3mm closed cell polythene foam over ply. Seemed to me that using long fixings into insulation board was going to give more trouble than it is worth.
Offline perz
#5 Posted : 01 January 2018 22:07:23(UTC)
perz
Screws won't hold if you screw them into the foam without anything else. I would recommend you to get some rigid 2 mm cardboard and cut out small squares (~2 x 2 cm) that you glue on top of the foam with white wood glue wherever you want to put the screws. This definitely works, I have tried.
thanks 1 user liked this useful post by perz
Offline Tom Jessop
#6 Posted : 02 January 2018 11:06:23(UTC)
Tom Jessop
If you are after noise reduction the only thing to do is attach the track to the track underlay then attach this to the plywood below. this way there is separation from the track to the baseboard . I used a Ozzy made underlay called TRACKRITE which I formed to fit between the walls of the rack & then white glue which attached the underlay to the foam beneath . Trackrite is almost the same as the insulation which is wound around hot water pipes & is easy to work with . In the FILES section there should still be a copy of my Trackrite instructions .
Cheers Tom in Oz .
Offline perz
#7 Posted : 02 January 2018 23:30:32(UTC)
perz
Hot glue would probably not work on foam. It has a tendency to melt. I haven't tried, though.
Offline LA2019
#8 Posted : 04 January 2018 01:39:59(UTC)
LA2019
I'm laying my C-track directly on pink insulation board. I sink a 1" dowel every so often to secure the track. I use a 7/8" paddle bit to drill into the foam. Works well for me....
Ken
USofA
thanks 3 users liked this useful post by LA2019
Offline Tom Jessop
#9 Posted : 04 January 2018 02:48:32(UTC)
Tom Jessop
Something popped up on the Bar & Grill this morning about using the Non Slip insert that goes onto kitchen draws , a type of open mesh weave but with a sticky surface both sides . Link to Post _
over the years there have been several ways to sound-proof a layout;
i.e. getting rid of as much resonance from the tracks to the layout
(the noise from the wheels to the rails cannot - should not be avoided)
cork - various plastics - rubber-like sheets etc etc
i've found that a simple “anti slip mat”
( antirutschmatte )
<https://www.rakuten.de/produkt/jes-collection-antirutschmatte-75-x-30-cm-verschiedene-farben-fuer-haushalt-boot-wohnmobil-auto-caravan-10-x-a-1553256050.html>
as found in various DIY stores - typical 75x30 cm
to be used as anti-slip in drawers or under rugs
- actually gives a very nice result - compared to price and work-effort
currently it can be bought for 1 (one) euro pr 75x30cm
laying it double gives a very noticeable result
added bonus - the c-track sticks to the mat as glue
PS
i’ve only so far laid it in the hidden areas
so I dont know how it works when creating landscape
around the c-track
Yours sincerely
Christian Vinaa
http://www.trains-and-trains.dk
....... Meanwhile, aunt Martha, having taken a tramp in the woods,
is lying in a ditch at the edge of town .........................
I haven't tried this yet but SWMBO told me that she has a bag full of the stuff some where in the garage , just a matter of finding it to see how it works with K or M track.
Cheers Tom in Oz .
Offline Albert Lind
#10 Posted : 04 January 2018 03:05:04(UTC)
Albert Lind
THANK YOU TO ALL WHO RESPONDED TO MY QUESTION ABOUT LAYING MARKLIN TRACK ON RIGID FOAM INSULATION. THESE ARE A LOT OF GOOD IDEAS.
thanks 1 user liked this useful post by Albert Lind
Offline blid
#11 Posted : 05 January 2018 16:40:26(UTC)
blid
Have you checked this thread: Sparrow's new shelf layout
https://www.marklin-user...s-new-shelf-layout/page3
Unfortunately the pictures can't be viewed anymore, but there are some videos on page 3. As far as I recall he made cutouts for the C tracks in the foam.
thanks 1 user liked this useful post by blid
#12 Posted : 07 January 2018 17:23:39(UTC)
I am always working with 3 mm cardboard "roadbed" glued onto white rigid styrofoam boards with white glue. C track is then fixed with screws driven into the 3 mm cardboard.
(I once used Liquid Nails adhesive to glue C track directly onto foam boards for the former Thunder Mountain layout. Worked well, but track removal was a mess when dismantling: not so good.)
This page was generated in 0.832 seconds.
