#1 Posted : 29 December 2017 06:23:54(UTC)
If I have a MS2 that has not been upgraded and want to use newer locomotives with it, how do I register the loks?
I tried to get it to scan for mfx lok for my new 39460, but it keeps coming back with keine Lok.
#2 Posted : 29 December 2017 10:22:23(UTC)
Good question, interesting question.
Some MS2s where shipped with version 1.1, others were shipped with version 2.5 or versions in between.
So I can definitely say you may need an update. Which version is your MS2?
You need 1.83 or newer for mfx+ decoders.
I don't recall which version is needed for ESU V4 M4 decoders, but the MS2 required a bugfix for those too.
Do you have version 1.83 or newer? Is the trackbox up-to-date?
You can disable mfx in the MS2 and drive the loco using DCC (default address 3). Automatic detection probably does not work in that case, the MS2 system is a bit buggy. Register the loco manually.
#3 Posted : 29 December 2017 17:31:22(UTC)
I have the MS2 which came with the 29486 BLS Set. I do not have a CS, CS2 or CS3 from which to update it and there is no Maerklin dealer in Montreal.
I managed to enter a lok with a DCC address of 3 and was able to access the lok.
I don't know if this is something new, but there seems to be a slight delay between command and control.
I will have to see if I get the same result with the 6021 or my Lokprogrammer test track.
This page was generated in 0.239 seconds.
