Offline Primo -23K
#1 Posted : 21 December 2017 04:33:54(UTC)
Primo -23K
hi, I am new to Marklin. I have been acquiring items over the past 30 years, and I am just in the process of building my rail setup. i have 11 turnouts to wire up and i am wondering if its possible to connect all this to a bus type wire system. Would this possibly eliminate a lot of wiring?
any info would be appreciated, as I cannot obtain this info on the internet.
Kind Regards
Primo Medves
trainset@tpg.com.au
#2 Posted : 21 December 2017 07:57:09(UTC)
Kind Regards
Primo Medves
trainset@tpg.com.au
Hi Primo, welcome.
Do you intend running classic Analogue or going Digital?
What if any, reference literature do you have already?
Steve
Offline Primo -23K
#3 Posted : 21 December 2017 09:59:28(UTC)
Primo -23K
Hi! Steve,
Thank you for your reply.
I am combining the Noch Mittenwald [59610] layout, with the Marklin 23k Layout [Book 0700 page 7.5 177] and the Noch 80120 [from the track plan 59100], which I have started.
at the present I am planing to complete the Noch 59610. i have completed the rails and connected to my transformers [2]. this was done via a bus wiring system which work very well.
and it will be done under the analogue system. the remaning plans will be initially analogue and then possibly to digital.
I have the following references.
signal Manual 0361
Electric manual 0715 [German/english]
Marklin Digital Book 0303 , 0368
a user guide to the Marklin digital system prepared by Dr. Thomas Catherall [4edition 1991/
Kind Regards
Primo medves
thanks 1 user liked this useful post by Primo -23K
Offline TEEWolf
#4 Posted : 26 December 2017 02:42:06(UTC)
Kind Regards
Primo Medves
trainset@tpg.com.au
Hi Primo,
meanwhile Maerklin offers some more books and information for digital railroad returners. See Maerklin article # 03092 "Controlling Digitally with the Central Station 3" in English.
https://www.maerklin.de/...s/details/article/03092/
Maerklin's information offers are unfortunately mainly in German. Nevertheless I want to show you some more sources:
https://www.maerklin.de/...men-specials-und-serien/
under this link you find plenty of information to a digital railway including cabeling.
https://www.maerklin.de/.../MM_Verkabelung_2013.pdf
Most of this article is also a chapter (page 150 and following pages) in the new book from Maerklin.
I bought the German version of this book and can highly recommend it.
Maerklin just published another brandnew book.
https://www.maerklin.de/...e/details/article/03070/
This one I just ordered, but have not yet received.
Maerklin also offers very special so called technical tipps - but unfortunately all in German and I did not yet found any translation in the internet. Here an example:
https://www.maerklin.de/...faq/Technik-Tipp-403.pdf
Offline Mr. Ron
#5 Posted : 31 March 2021 08:01:48(UTC)
Mr. Ron
Hi! Steve,
signal Manual 0361
Kind Regards
Primo medves
On an analog system, the yellow wire from each turnout can go to a common bus wire, but the other 2 wires,(red and green) must run independently to the controller, 7072 if you are using M track.
This page was generated in 0.284 seconds.
