#1 Posted : 06 December 2017 05:20:18(UTC)
Thought some of you might like to see the little tip I developed to replace missing the missing Window cellon on older models.
I first did this with an old HAMO Tram a few months ago and was very pleased with the result so I thought I would try it on my ST800 Body Shell.
It just shows what can be done with what you might have lying around home. In this case, a plastic bottle (Cream or Milk)
The bare Body Shell - no windows
The plastic bottle - (600ml cream)...
Cut an incision, then cut with scissors a long strip roughly a bit wider (this one is 2cm) than the finished product needs to be... (to allow for smooth trimming)
(note that I cut the strip in a spiral around the bottle so that I could get the required length in a single strip)
Now trim the strip for a smooth edge and constant width - I used an old drawing-board with a T-square simply because I had one but you could just do it easily with a ruler
Now fit the strip into the body shell, very easy on this model because it has guides for the windows to fit into...
Trim ends as required....
The End Product... not bad aye?
I just need to finish the handrails, I have some stainless-steel dental wire which is perfect for this, just as soon as I can find where I stored it!!
(and now compare with a random image of the same item taken off the internet just now - I'd be happy with that
Hopefully this might inspire someone with a Loco or Coach missing some windows to put it right - this took me about 15 minutes start to finish - cost? $0.00
thanks 11 users liked this useful post by cookee_nz
Offline Markus Schild
#2 Posted : 06 December 2017 10:33:22(UTC)
Markus Schild
Hi Cookee,
Very nice. In the past I used white drawing film. That is easy to cut and has an impression near to the original.
Markus
Offline Thewolf
#3 Posted : 06 December 2017 13:30:16(UTC)
Thewolf
Cokee Cool
Fabulous job Cool
Thewolf
#4 Posted : 06 December 2017 16:42:30(UTC)
yes it is amazing what we have at home and can be used for things we normally wouldn't think of.
Offline White Buffalo
#5 Posted : 24 December 2017 05:04:23(UTC)
White Buffalo
Excellent idea!
thanks 1 user liked this useful post by White Buffalo
Offline Troy Yang
#6 Posted : 26 December 2017 07:19:31(UTC)
Troy Yang
Very clever and nice. Laugh
thanks 1 user liked this useful post by Troy Yang
This page was generated in 0.577 seconds.
