Offline FV1974
#1 Posted : 21 November 2017 21:30:24(UTC)
FV1974
When I run my trains, the lights work in opposite direction of travel. ie when I go forward, the rear lights of theengine work and vice a versa. How can I get that changed so that the lights are in line with the direction of travel?
#2 Posted : 21 November 2017 23:14:41(UTC)
Could you give us some more information?
It would be helpful if you told us what loco you are referring to. What's the catalogue number? Is it digital or analogue? if it's digital what decoder is fitted?
#3 Posted : 21 November 2017 23:31:27(UTC)
Frank, Fred, Fletcher,
To change it, it depends on: if analog what type of loco, what type of decoder if digital: has it an 8 pin plug ?, what type of decoder, manufacturers name, if ESU you would need a loco programmer to change it or change the light wires from front to back. has anybody done any work on your loco ?
regards.,
#4 Posted : 22 November 2017 07:55:06(UTC)
For locos with the C90 motor you just have to turn the magnet around to reverse the direction of travel. This may have happened while cleaning the loco.
With modern decoders the direction can be changed via decoder programming - depending on the decoder model.
Offline FV1974
#5 Posted : 22 November 2017 08:45:26(UTC)
FV1974
It applies to all my locos making me wonder whether it has something to do with how I have set up my Delta and connections. My three locos are
3021 v200
3357
3040
I can’t remember anyone having serviced them. But then again I haven’t used them for 25 years and can’t remember what I did at the time when I introduced the Delta system to my set.
I am using a 16A transfo and the Delta selector (4 connections)
#6 Posted : 22 November 2017 09:15:46(UTC)
3021 v200
3357
3040
try reversing the wires going to the track or visa versa to the transformer: red wire to middle track and brown wire to outer track.
#7 Posted : 22 November 2017 10:02:49(UTC)
So maybe it was always like that because lights were wired the wrong way around in the first place.
With Delta decoders, swapping wires in the locos is the only option I'm aware of.
Swapping wires between Delta controller and track or between transformer and Delta controller probably won't make any difference.
Do the wires for front and rear lights have different colours with your decoders? If so, make sure the lights are wired correctly. If so, swap the blue and green wires going to the motor.
This page was generated in 0.493 seconds.
