Offline jimwallace1652
#1 Posted : 29 October 2017 22:15:10(UTC)
jimwallace1652
Have lots of M track and remote/electric controlled switches on layout. Most switches use larger lanterns.
Switches with large lanterns cause derailment when turning for longer cars such as 43584 DB passenger car.
Cars do not have a problem using switches e.g. 5202 that have smaller lanterns.
Is there a kit or process to change out larger lanterns for smaller lanterns?
I do not want to replace switches. I just want to change out the larger lantern for the smaller lantern only without pulling up track.
Thank You
Offline Br502362
#2 Posted : 30 October 2017 08:04:52(UTC)
Br502362
Hi Jim,
I remember reading old 60's Märklin Magazine and there was an article from
converting large lanterns to small lanterns. It included necessary part numbers
and photos from the work done.
I beleive that those parts aren't available anymore from Märklin.
Åke
Offline Br502362
#3 Posted : 30 October 2017 19:35:03(UTC)
Br502362
Hi again,
It was actually Märklin Magazin 3/78 where the upgrade was described.
I hope that this helps you Smile
Åke
thanks 4 users liked this useful post by Br502362
#4 Posted : 30 October 2017 21:45:04(UTC)
jimwallace1652
Thank you very much for the information, diagram and part numbers.
You are great.
Thank You Very Much
thanks 1 user liked this useful post by jimwallace1652
#5 Posted : 30 October 2017 23:18:14(UTC)
It is really easier and cheaper just to buy the new style m-track turnouts. They are still pretty cheap on eBay. The problem is that they very often need a good refurb before they can be used reliably on a layout. Martin has a good video on giving old m-track turnouts a new life..
thanks 4 users liked this useful post by xxup
Offline sjbartels
#6 Posted : 31 October 2017 04:55:38(UTC)
sjbartels
Hi again,
Åke
Thanks for that article Åke, that was great. It's going to help me with something I've planning, so thank you!
thanks 1 user liked this useful post by sjbartels
#7 Posted : 31 October 2017 05:27:40(UTC)
There's also an article a few editions earlier which shows how to modify 5127 manual points for electric operation.
Offline sjbartels
#8 Posted : 31 October 2017 17:36:23(UTC)
sjbartels
Do you have that article? I’ve some manual 5127 that I can’t even give away I’d love to automate
Offline MKOpSeattle
#9 Posted : 04 February 2021 07:32:18(UTC)
MKOpSeattle
Has anyone tried the conversion and made it work?
I learned it the hard way after I did test running on my new M track layout that the old 5202 and 5117 turnout lanterns are rubbing against the 43571 coach. From Åke's diagram, I'll need 35605(left) or 35609(right), 75004(screws) and 75701(nuts). I also need to cut the plate to 28.5mm and drill two holes. I can't read German and that's all I can understand from the diagram.
I'd appreciate any tips if anyone has done this. Thank you Åke for the diagram.
Thank you.
T
thanks 1 user liked this useful post by MKOpSeattle
This page was generated in 0.683 seconds.
