Offline phantomtracer
#1 Posted : 27 November 2008 02:00:33(UTC)
phantomtracer
I was planning on getting the ESU v3 update for my CS1.
One feature is DCC compatibility.
Does that mean I can run a two rail DCC loco on my 3 rail Marklin track if I add a pickup shoe for the third rail?
Would I have to modify the motor?
Any comments on this topic would be appreciated.
Phil
Offline Seetal
#2 Posted : 27 November 2008 03:22:52(UTC)
Seetal
Hi Phil,
DCC decoders can be controlled in parallel with Marklin protocols. So that should work. The other element is the conversion from 2 rail to a three rail. There are a few topics discussing this, I have not tried. My general impression is that it is eaiser to go from 2 to 3 than from 3 to 2. Try the search feature to find some topics.
#3 Posted : 27 November 2008 03:23:43(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by phantomtracer
<br />Does that mean I can run a two rail DCC loco on my 3 rail Marklin track if I add a pickup shoe for the third rail?
Yes you can. You will probably also need to electrically connect both wheelsets together too.
<br />Would I have to modify the motor?
Probably not, as the loco would be working in DCC, as it was designed to. The only difference would be the method the electrical current travels to get to the motor.
#4 Posted : 27 November 2008 18:21:34(UTC)
Hi, Phil!
You can also run the majority of 3rd party three-rail locos with DCC because they normally come with multiprotocol decoders for MM and DCC.
This page was generated in 0.476 seconds.
