#1 Posted : 11 October 2017 19:26:10(UTC)
I know that there is some locomotives still have 3 pole motor but this time with mSD3 new generation decoder.
What i want to know is that there is better motor performance with the new decoder mSD3 than the old mfx?
For exemple 37003 VS 37008 diesel V100?
Offline MaerklinLife
#2 Posted : 12 October 2017 06:11:45(UTC)
MaerklinLife
In my opinion the msd3 performs very well with 3 pole motors. I have several 36xxx locokotives fitted with msd3. No problems, smooth running and so on.
Offline dickinsonj
#3 Posted : 13 October 2017 03:31:26(UTC)
Yes - totally true!
Even relatively primitive 3 pole motors run very well when regulated by modern PWM decoders like the mSD3 or ESU V4's. That is why you see makers returning to simpler 3 pole can motors more and more, because they work perfectly well when controlled with modern electronics. Adding more poles compensated for prehistoric electronic controls and I always tried to buy only 5 pole motors 10 years ago.
But honestly, they are no longer absolutely needed when used with advanced electronic motor controls.
#4 Posted : 13 October 2017 06:19:44(UTC)
MaerklinLife
My findings are that at the moment, the msd3 (or mld3) controls the motors better than the ESU 4. Just a slightly smoother running when accelerating. The ESU tends to jump at certain points when accelerating. I have not been able to adjust variables to get rid of the jumping or uneven running. The msd3 is for me the #1 choice for the 36xxx locomotives.
thanks 3 users liked this useful post by MaerklinLife
#5 Posted : 13 October 2017 08:58:05(UTC)
They didn't run well in the days of the MSD. Märklin started using 3-pole motors before they had appropriate decoders. This way they lost my trust.
Now I read that the MSD3 does a good job - but the trust does not come back automatically.
Good five-pole motors are less challenging for a decoder and I believe they will perform better than three-ole motors using the same decoders.
#6 Posted : 13 October 2017 09:30:17(UTC)
What about to use DCC protocol?
It present with 28 or 126 speedsteps.
I´m pretty sure it does make difference between 28 and 126 speedsteps with the 3 pole motor.
Offline dickinsonj
#7 Posted : 13 October 2017 14:18:37(UTC)
I totally agree about trust in a brand and how it is difficult to re-establish once it is lost. For me it has been many small problems with new Märklin models which have eroded my trust in their products. I went for quite a while without buying any new MRR equipment after significant failures with both Märklin and ESU products.
I have several newer locos with mSD3 decoders and cheaper 3 pole can motors and they run flawlessly. I can set them to the smallest speed step at which they will move and they will crawl smoothly around my layout indefinitely, even with a long train behind them. I do not see how a 5 pole could perform any better. In the past I was a motor snob (Faulhaber motors rule!) but I have moved past that. I personally regret that these cheaper motors don't have replaceable brushes though, which I see as a bigger issue than the number of poles.
I write software to control hardware and over the last 10 years it has become an industry trend to use lower spec motors and then to compensate with higher quality electronics. I'm not saying that is necessarily the best trend but Märklin is hardly alone in doing this. I will run the cheap motors until they fail and then replace them with better quality motors, which are often available at reasonable prices.
#8 Posted : 13 October 2017 19:46:25(UTC)
MaerklinLife
5 pole is not always better. A good 3 pole will perform better than a crappy 5 pole. IMO.
thanks 1 user liked this useful post by MaerklinLife
#9 Posted : 14 October 2017 05:00:33(UTC)
....three-ole motors......
Confused BigGrin Flapper
This page was generated in 0.477 seconds.
