Offline itzik
#1 Posted : 05 September 2017 10:16:11(UTC)
itzik
Israel
Hello All !
I have a Marklin BR24 Loc. (3003) With Delta decoder (70117B WITH 4 Dip switches - configured with digital address 24) – Picture includeded-, and have a lot of problem to operate it using my Uhelnbrock IB-Com with Rocrail.
Would appreciate to receive any advice / recommendations / help /Manuals or any tips from those who have experience ,- how to convert this Loc. With a standard Motorola Format Loc. Decoder (esu lokpilot or any other company that will feet in the Loc.)
Itzik
Offline ktsolias
#2 Posted : 05 September 2017 12:01:33(UTC)
ktsolias
Hi Itzik
A good option for 3003 loco with a value around 50 Euro is the use of a cheap combination of motor decoder.
There is no kit available so you have to use the 60943 motor kit (SFCM) and a decoder of your taste. Any decoder will do the job with the DC motor. You can use the basic fx Marklin decoder from the 60760 kit and you will have the motor 60941 from the kit to use in another conversion.
Or you can use an ESU Lokpilot4 or any other.
Costas
Offline Johnvr
#3 Posted : 05 September 2017 15:27:04(UTC)
Johnvr
I agree - using a 60943 motor and a decoder from the 60760 kit is a good option.
I have converted two of mine (3003 locomotives) using the above kits and they run very well on the layout.
Regards,BigGrin
#4 Posted : 05 September 2017 15:43:57(UTC)
Originally Posted by: itzik Go to Quoted Post
..... and have a lot of problem to operate it using my Uhelnbrock IB-Com with Rocrail.
I think changing the decoder type is unlikely to solve the problem unless the existing decoder itself is faulty.
  • What problems are you having?
  • Are other locos working OK?
  • Is the IB set to the correct Motorola protocol for address 24?
Offline itzik
#5 Posted : 05 September 2017 16:27:27(UTC)
itzik
Israel
Hi Costas, John & Dale
First - Costas & John - thanks for your advice - I will definitely check your advice. from your experience - how difficult is making the change ?
is the kit come with details manual ??
and Dale - finally after investigation - I solve my problems just a hour ago !
incorrect configuration of dip switch address (must put my glass next time... Confused ) and a short circuit in one of rail feeder.
Loco now working BigGrin (not smooth as my new one)
Thank's
itzik
thanks 2 users liked this useful post by itzik
Offline Ross
#6 Posted : 06 September 2017 00:00:33(UTC)
Ross
Hello Itzik,
I have converted this loco and below is an article on the things I did.
3003 Article
It is a simple conversion to do.
Ross
thanks 2 users liked this useful post by Ross
Offline itzik
#7 Posted : 06 September 2017 07:11:25(UTC)
itzik
Israel
Hi Ross
Great !! ThumpUp many Thank's - very detailed article, definitely will help me
itzik
thanks 1 user liked this useful post by itzik
This page was generated in 0.547 seconds.
