Offline Thewolf
#1 Posted : 15 August 2017 22:46:17(UTC)
Thewolf
Hi all Cool
I decided during the reconstruction of my layout not to use anymore marklin plugs and sockets
I want to buy a digital soldering station.
I believe the mark Weller would be best ... but it is too expensive
Do you have suggestions on this matter?
Thank you for your reply
Thewolf
Offline michelvr
#2 Posted : 15 August 2017 23:53:57(UTC)
michelvr
Velleman solder station
The best bar none!
Sayal Electronics and Hobbies
Michel
thanks 2 users liked this useful post by michelvr
Offline siroljuk
#3 Posted : 16 August 2017 15:28:45(UTC)
siroljuk
Hello.
I bought such a STAMOS soldering station from Germany and it is a good soldering station with hot air blower nozzles and several solder blades. Good and cheap
STAMOS S-LS-17
Jukka
thanks 2 users liked this useful post by siroljuk
Offline michelvr
#4 Posted : 16 August 2017 15:39:26(UTC)
michelvr
Originally Posted by: siroljuk Go to Quoted Post
Hello.
STAMOS S-LS-17
Jukka
Hello Jukka,
Very nice too bad we can not buy that in Canada! I like the hot air blower would be a great benefit to blow away the fumes.
Michel
Offline Thewolf
#5 Posted : 16 August 2017 19:41:30(UTC)
Thewolf
Thank you to Michel and Jukka Cool
I appreciated your advice Cool
Michel, ..sorry but I do not know how to read the description of the model on your photo
Thank you
Thewolf
#6 Posted : 16 August 2017 19:44:42(UTC)
I've used the Weller WESD51 Digital Soldering Station (yeah, it is $137).
The key is the ability of the station to keep the temperature that you set it to. Note that doesn't mean that it has a display of a temperature -but that the temperature is actually the value indicated.
This lets you crank up the temp when soldering near plastic: counter intuitive, but a hotter iron means you can heat up the solder point on the rail quicker to get the wire soldered on fast, rather than a lower temp that will heat the rail for a longer period and cause the plastic ties to melt.
Or turn down the heat if soldering on a circuit board where you don't want to damage the electrical traces on the board.
Having a sponge (to keep the tip clean) a solid stand (to keep you from knocking the iron over or burning yourself or your work) and a solid temperature control are the key features. Other brands do that as well.
If you do more extensive electronics, then a station that has more capabilities such as de-soldering (for circuit board work) or heat-gun capability (for reflow soldering on spots, etc) can be usefull but is probably overkill for model railroad.
That said, a simple pencil iron can be sufficient if your only doing soldering of wires to tabs but for soldering to k-track rails and the like I'd want one with a lot of power.. .and you still need the stand and sponge in some form... and the pencil only ones have the main lead come out the back of the iron which is more stiff than the leads from the soldering stations. The station wires being more flexible make the iron a bit easier to maneuver.
thanks 4 users liked this useful post by Minok
Offline TEEWolf
#7 Posted : 17 August 2017 03:32:46(UTC)
The key is the ability of the station to keep the temperature that you set it to. Note that doesn't mean that it has a display of a temperature -but that the temperature is actually the value indicated. ...
wow, only $137! I got more for you, a $137 is really not expensive. Blink Have a better price for you - get a look here:Cool
https://www.reichelt.de/...XD+2020&SEARCH=%252A
1.219 € = 1.438,34 $ (exchange rate from Aug 14th).Laugh
Seriously: I do have a very little and limited experience in soldering, but for what reason do somebody needs such an expensive station? I bought one for 20 € (which is 23,60 $).
#8 Posted : 17 August 2017 06:23:01(UTC)
Originally Posted by: michelvr Go to Quoted Post
...too bad we can not buy that in Canada! I like the hot air blower would be a great benefit to blow away the fumes.
Why not? These types of soldering stations are a dime a dozen off aliexpress. No different to buying your Marklin from Germany.
Soldering stations have been discussed in previous threads - will see if I can find tbem.
There was a Marklin branded station - check the 2005 catalog for a descrption. It isn't available now though.
#9 Posted : 17 August 2017 07:22:34(UTC)
Offline Thewolf
#10 Posted : 18 August 2017 13:07:50(UTC)
Thewolf
Hi all Cool
Thanks to all for the advice
I think that I am going to order this :
http://www.cafr.ebay.ca/itm/162578083509
Have a nice day
Thewolf
Offline PMPeter
#11 Posted : 18 August 2017 15:10:14(UTC)
PMPeter
Hi all Cool
Have a nice day
Thewolf
Be careful. Check the voltage. You need one that can operate on 120 V 60 Hz supply here in Canada.
Offline Thewolf
#12 Posted : 18 August 2017 15:23:34(UTC)
Thewolf
Hi all Cool
Have a nice day
Thewolf
Oh yeah ...you're right ...I have forgotten this point
Offline Thewolf
#13 Posted : 18 August 2017 16:38:59(UTC)
Thewolf
I found this model in a company near me ... I am going to inquire .. this model seems to me correct for what I am going to make with
http://www.kge.ca/fr/pro...s-pour-le-hobbyiste.html
#14 Posted : 18 August 2017 20:35:43(UTC)
There are always more expensive options. And what is expensive to one person isn't to another (eg I don't find $140 expensive, but others might find a soldering iron over $30 expensive).
Why would you need that - it has de-soldering capability, which is a critical feature if you are doing electronics/circuit board repair. It has special hollow tips and a vacuum system to allow the extraction of solder away from the boards to allow parts to be removed and replaced. And it does it in a reliable and rapid manner. There are small pump type systems and solder wicks that work ok for occasional work, but if your working on a lot of stuff day in and day out such an expensive part is worth the money in time saved and other material costs as well as reliability.
Same goes for fume extraction systems - some just are fans that pull the smoke/air/paint away from the face but blow it out the back of the hood and back into the room - so you breath it later at a lower concentration, or it settles over the room. The more expensive ones blow the air through a set of filters and media that removes the non-air substances from the extracted air and blow the cleaned air back into the room.
For the MRR hobby where soldering is a very occasional thing, but you work around plastics - to be easier to work, a $100 station is a good option, but a $30 pencil iron will do for many and just needs a bit more care in use and is slightly harder to use.
Offline DB Fan
#15 Posted : 18 August 2017 20:59:48(UTC)
DB Fan
That is a great soldering station. I have the same one and it works great for soldering on my engines and other model train items. I found mine online for about $45.00 2 years ago. Was ether amazon or eBay. Also bought a starter kit for soldering and a set of different soldering tips for it as well. Have fun with it.
Happy Model Railroading
Robert
Offline Darren W
#16 Posted : 19 August 2017 18:23:12(UTC)
Darren W
Check out the Hakko brand of soldering irons they are good and available here in Canada.
http://www.canadarobotix...fx888d-soldering-station
Darren
Guest (4)
This page was generated in 0.452 seconds.
