Offline darticus
#1 Posted : 11 August 2017 22:08:53(UTC)
darticus
I hope someone can give some suggestions on what to build. I have a table with a working area its 19.5 inches by 45.5 inches. I would like to run two trains at one time but I would like the look of more than 2 sets are running. Maybe a yard would be nice. Possible oval with figure 8 with it than scenery. Hope I can get some suggestions I have 2 Marklin sets to use. Maybe some layout pictures. Not new to trains but just getting started again. Thanks Ron
Offline zscalehobo
#2 Posted : 12 August 2017 00:25:26(UTC)
zscalehobo
Rokuhan has a nice "layout" portion of their site. I know we're on a Marklin-centric forum, but you can map many Rokuhan part numbers to Marklin (not all).
http://rokuhan.com/english/layout/index.php
Frank Daniels
Owner - z.scale.hobo
A Noch "Top Dealer"
Irvine, California, USA
www.zscalehobo.com
thanks 3 users liked this useful post by zscalehobo
Offline Carim
#3 Posted : 12 August 2017 08:28:20(UTC)
Carim
Hi Ron,
As a starting point, why don't you Google "Marklin Z track plans" and then view the images - there seem to be a lot of interesting, small plans. Secondly, along with most sets, Marklin issues a track geometry pamphlet that includes a number of track plans; try getting hold of that.
Carim
Offline darticus
#4 Posted : 14 August 2017 01:39:27(UTC)
darticus
Thanks to all but still searching. Their kit are not giving too much help. Great stuff on the internet but how to tell what number Marklin tracks to use. Thanks Ron
Offline Wal
#5 Posted : 15 August 2017 01:31:04(UTC)
Wal
Hi Ron,
I currently have a 2.4 x 1.2 metre layout which I need to downsize, so I'm right in the middle of track planning. On my Windoze PC I use a piece of software called Anyrail to design my layout. It supports Z scale, has all of the Markin Z track templates (as well as Rokuhan and others). Once you've designed your layout you can press a button to see a detailed inventory of all the required track. It also does flex track, grades and can warn of excessively tight curves or steep grades. If you use blocking to create sections to facilitate automatic multiple train operation on a single track then it colour codes these as well. It's helping me get my head around what I can fit into my new layout size. Hope this helps..
Wal
thanks 1 user liked this useful post by Wal
Offline gatorpharmd
#6 Posted : 04 September 2017 04:05:58(UTC)
gatorpharmd
Thank you Ron and Frank, I was able to modify one of the Rokuhan plans for Marklin track using RailModeller Pro, it is still preliminary but close to what I wanted considering I have limited space in my apartment. Huge thanks. Tony
Preliminary track plan
thanks 1 user liked this useful post by gatorpharmd
Offline darticus
#7 Posted : 07 September 2017 01:16:20(UTC)
darticus
Very nice layout. I really wanted a layout that could run two trains different directions and a figure 8 in the middle. Without a million pieces of track to play with I'm having trouble building or thinking how to build something. Thanks Ron
Offline gatorpharmd
#8 Posted : 07 September 2017 03:04:54(UTC)
gatorpharmd
Thank you Ron, I have very limited space. I have been working on it, I was able to reduce the length of the baseboard to 22 x 48 inches.
Guest (4)
This page was generated in 0.258 seconds.
