#1 Posted : 20 July 2017 08:34:23(UTC)
Everybody knows that digital voltage is constant voltage on the track?
But what happens with the track about there is too much metal?
Does not this oxidation cause ionization around the track due to constant voltage?
Märklin tracks consist of precious steel and beck plate as K-rail for example.
So I would like to know if you do not experience any strangers digitally on the Märklin track?
#2 Posted : 20 July 2017 20:11:59(UTC)
Hi Goofy,
Digital is unbalanced chopped voltage and not DC
Because of recent motor design (dc and worm drive) when there is a current pick-up issue, the stop is more abrupt than with old-style marklin motor and transmission, that was more foregiving (the loco would not stop.
Online Purellum
#3 Posted : 20 July 2017 21:38:50(UTC)
I think the answer is no.
Or it could be yes.
Maybe.
#4 Posted : 20 July 2017 23:06:57(UTC)
Well, yes. Constant voltage, constantly changing polarity (about 10,000 times a second).
With SX or RailCom, the track power is constantly being turned on and off besides the changes of polarity.
The answer is: "Definitely maybe."
Ionisation, oxidation, parasitic capacitance, rubber traction tyres, power detonations: it is a miracle that digital railways move at all.
#5 Posted : 21 July 2017 03:34:51(UTC)
Let alone the 'Digital Strangers'! OhMyGod
#6 Posted : 21 July 2017 08:22:52(UTC)
The reason I started this thread is because I encountered a friend who is now the former Märklinist.
He told me he went over to two rail instead and thinks it works better.
So less worries than driving with three rails.
It´s the motive I did asked in my first thread post.
#7 Posted : 21 July 2017 10:51:16(UTC)
Each to their own I suspect, but I wouldn't believe so easily everything everyone says to me!
I suspect before long your friend will have more worries with 2 rail. Reversing loops being one of them!
#8 Posted : 21 July 2017 11:07:14(UTC)
There are different types of Märklin tracks.
There is M track and K track with tin-plate rails - rust can be a problem with those.
There is C track and K track with stainless steel rails - but the centre rail is tin-plate and rust can still be a problem.
And dirt from traction tyres can always be a problem.
Switching to two-rail with nickel silver rails and only using locos without traction tyres will eliminate two potential problems.
But two-rail digital and three-rail digital use the same "constant" voltage, so any problems caused by the (not so constant) "constant" voltage will apply to both rail systems - unless the material (nickel silver vs. tin-plate vs. stainless steel) makes a difference.
You wrote "thinks it works better". Does not sound like empiric evidence.
Did he switch from digital to analogue?
#9 Posted : 21 July 2017 15:10:32(UTC)
Reverse loop in digital have no problem.
I did created an topic about digital interference with three rail by asked to member here.
You should stand by to focus about the thread.
My friend did had problem with Märklin and walkover to two rail digital with lesser problem.
#10 Posted : 21 July 2017 15:14:30(UTC)
No he use digital.
Yes it makes difference.
#11 Posted : 21 July 2017 20:59:54(UTC)
What is the topic of the thread? Its hard to extract from the initial post.
There is no engineering reason your friend should have less problems with 2 rail DCC than 3 rail MFX (lets just say). Each system has advantages/disadvantages.
Now if there is some aspect of this friends layout location / design / maintenance or construction regime that unexpected, it could cause a particular problem, but its not clear from the thread what the friends problem actually is/was other than the claim that he had less of said unknown problem once he switched.
Digital interference - not sure what that is asking about. If there is other present RF in the air around the layout, the tracks could pick up that like an antenna, and if those signals are of frequencies around the mfx based signalling, that could cause some problems with decoders.
If its about electrical contact to the rails and center studs - that depends on cleaning the track regularly; you have to clean 2 conductor DCC just as much as 3 conductor DCC/MFX.
thanks 4 users liked this useful post by Minok
Online Purellum
#12 Posted : 21 July 2017 22:53:50(UTC)
Every person ever, who went from 3-rail to 2-rail, now think 2-rail works better.
And every person ever, who went from 2-rail to 3-rail, now thinks 3-rail works better.
Nothing new.
It has nothing to do with interference, oxidation or digital strangers. LOL
thanks 4 users liked this useful post by Purellum
Offline MaerklinLife
#13 Posted : 22 July 2017 06:00:55(UTC)
MaerklinLife
...not that I know many who did that...
Online Purellum
#14 Posted : 22 July 2017 08:10:11(UTC)
That's just natural.
Not many wants to tell about their former life on the dark side. LOL
#15 Posted : 22 July 2017 14:05:34(UTC)
No, but reversing loops in 2 rail layouts have lots of problems.
You're the one who changed the topic to 2 rail......
#16 Posted : 25 July 2017 08:59:36(UTC)
Never had problem this with reversing loops.
No you did started by write 2 rail equal 3 rail complaint.
Please Stick to my first post!
#17 Posted : 25 July 2017 12:22:34(UTC)
You'll be saying that the Earth is flat next......
#18 Posted : 25 July 2017 14:58:27(UTC)
Or that the CS3+ is the best controller ... BigGrin BigGrin BigGrin
#19 Posted : 25 July 2017 21:51:34(UTC)
Quickly throwing down my Christmas carpet-bahn with a reversing loop at each end to form a dog bone with a single rail between the two ends, and no need to drive the turnouts (as the trains cut them on the way back)... simple as plug the tracks together and run the train with 3-conductor Märklin. With 2 rail DCC I'd have had to wire in isolated sections on both ends and put in reversing loop controllers (where would I hide those on my simple floor diorama - extra work).
For a built up semi/permanent layout there isn't a real problem, but for a space-constrained simple carpet bahn there are distinct advantages to the Märklin 3-conductor system.
Online Purellum
#20 Posted : 25 July 2017 22:14:20(UTC)
Probably because you've always have had an "end to end" layout. LOL
This page was generated in 0.642 seconds.
