Offline gwolski
#1 Posted : 07 July 2017 18:14:14(UTC)
gwolski
SUMMARY:
In 1983 the Austrian Federal Railways ordered Jenbacher Werke AG from Tyrol to order diesel-hydraulic traction cars similar to the DB series 627 with a drive output of 423 kW. After thorough testing, 100 one-piece units were supplied to the ÖBB as series 5047 and ten two-segmented motor vehicles of the 5147 series. 5047 were also sold to the Steiermärkische Landesbahnen (STLB), the Raab-Ödenburg-Ebenfurter railway (GySEV) and to the Nordfriesische Verkehrsbetriebe AG, Niebüll (NVAG). The traction units were designed in lightweight steel construction and can be used in multiple traction.
These two vehicle types (5047 & 5147) replaced the old series 5044 , 5144 , 5145 , 5146 and 5081 , which were technically out of date and at the end of their economic useful life.
5047 info page (German): https://de.wikipedia.org/wiki/ÖBB_5047
This review is for the HO scale Rivarossi HR2374 ÖBB Class 5047 diesel railcar in gray / red livery with running number 5047 090-5, named Manfred.
SET UP CLOSE:
Roof detail is minimal but present - some light weathering would make the details pop. Painting is, as with most modern locomotives, excellent with no overspray. Color demarcations and lettering are crisp and readable.
Underbody detailing is present but minimal. Trucks have minimal detail but are mostly hidden. The cab ends are well detailed including windshield wipers and non-functional buffers. I'll let the pics speak for themselves.
DIGITAL:
The 5047 is digital ready with a 21-pin (MTC) interface. The decoder and speaker are easily accessible through a hatch on the bottom of the railcar. I installed an ESU LokPilot decoder, and the railcar runs well if a bit stiffly. I need to give it some more time for break-in, and I have not yet tuned the decoder’s motor parameters. Both should smooth out the stop/start a bit – I’ll update the review later once I’ve had time to accomplish this.
The railcar has the standard 3xwhite front /2xred rear lights with the front lights on F0 and the red lights separate on F2.
Note on sound – I’ve not yet located any 5047 sound files for the ESU LokSound decoder. However, I have found sound projects for Zimo sound decoders available for order online.
I’d also like to install some interior lighting and passengers – I’ll update this review once I get the lights wired and passengers seated.
CLOSING:
I really like this railcar – the paint scheme is modern, and the body style is distinctly different from both my Jouef diesel railcars and my electric railcars. I need to do some motor tuning, and I’d love to have sound installed as well. Overall, I’m very satisfied with the 5047 Manfred.
3 RAIL VERSIONS:
I have not recently seen any 3-rail versions of this railcar, although I have seen older (closed) auctions advertising AC/3-rail. It’s not clear whether these are conversions or factory supplied. This 2-rail set is digital ready with a 21MTC decoder interface.
Gene Wolski
thanks 7 users liked this useful post by gwolski
#2 Posted : 08 July 2017 09:12:48(UTC)
thanks for the review, personally I can't see any problems adding a pickup shoe to the front bogie, there is enough recess to add one, to rewire the unit all you would have to do solder both left and right hand track contacts together and use the wire from the pickup shoe on its appropriate solder pad.
regards.,
Offline gwolski
#3 Posted : 08 July 2017 13:55:25(UTC)
gwolski
regards.,
I agree - the non-powered truck appears to have a mounting pad with center hole perfect for installing a pickup shoe.
Cheers!
Gene Wolski
#4 Posted : 12 July 2017 16:41:28(UTC)
regards.,
Cheers!
you may also have to change the wiring for the head and marker lights, all depends how it is set up
#5 Posted : 12 July 2017 22:56:14(UTC)
The issue with the ski might be clearance over switch pukos. The last rivarossi I converted assembled ok, but when going over tall switchpukos it flattened the play in the slider and listed the loco off the track! Still haven't stopped and sorted how (if possible) to remedy the situation
Offline gwolski
#6 Posted : 13 July 2017 16:41:43(UTC)
gwolski
Here are some 3-rail conversion notes I found - https://www.stummiforum.de/viewtopic.php?t=50079.
This article speaks to using a Brawa pickup shoe as well as replacing the traction tires with Marklin parts.
Cheers!
Gene Wolski
#7 Posted : 08 December 2024 09:43:38(UTC)
I've received my Rivarossi railcar today from an Australian auction house, its not the ÖBB version, I also noticed since than when this topic was posted, ESU has now a sound file for this rail car, S0349, I've installed a sound decoder V 5.0 with a 28mm round speaker and just doing an upload., I see if I can find the Austrian version of the ÖBB housing
Guest (5)
This page was generated in 0.351 seconds.
