Offline Giles
#1 Posted : 30 June 2017 19:21:56(UTC)
Giles
The string leading to the hook of my crane got tangled on itself.I did manage to remove the drum that the string wraps around. Presently, the sting is shorter than it should be. I would like to know how to service the crane properly. I got away with the uninformed butcher technique, but I would like to reenter this crane's mechanism with knowledge next time.
#2 Posted : 01 July 2017 02:55:29(UTC)
#3 Posted : 08 July 2017 06:56:45(UTC)
Hi Giles,
Here are two pictures of my opened 46715 digital crane:
Rear View
Side View
[img]https://postimg.cc/image/51zo530np/]UserPostedImage
It has been a while since I last opened it.
I think it is about unlatching the plastic housing from the rear to lift it
I hope it helps
Edited by user 12 June 2018 14:46:23(UTC)  | Reason: images disappeared
Offline shunter
#4 Posted : 08 July 2017 11:56:03(UTC)
shunter
Very interested in this as I have the same problem with mine.
Send it back to the service center of Marklin in the Netherlands but they didn't want to touch it and got it back unrepaired
Didn't dare to open it myself until now maybe
When the world is running down, you make the best of what's still around.
Offline Giles
#5 Posted : 11 July 2017 16:06:52(UTC)
Giles
Hi Giles,
Rear View
Side View
I hope it helps
I took the cab off the same way you did. The tricky part for me was removing the black "wheels" as seen the top rear of the crane to rewind the string. I can offer no help as I used the Mickey Mouse, take my chances technique. Maybe I just got lucky. I sure would like to know how to fix it properly.
#6 Posted : 09 June 2018 23:27:45(UTC)
I also need to open my crane up, as it pulled its jib and hook up as far as it will go and wont let it down....
The user posted images in this thread no longer load... does anyone have images of the inside?
#7 Posted : 12 June 2018 14:55:51(UTC)
Hi Dale
I have refreshed the 2 pictures on my 46715 crane.
To open it you need
- it you can arrange to unwind as much as you can both the hook and the boom wires
- to separate the flat car with current pick-up
- to unlatch with a small screwdriver both the bottom front and bottom end of the cabin to open it
Side View
Rear View
[img]https://postimg.cc/image/vls978179/]UserPostedImage
The Marklin wire is very thin and strong but "breaks" with aging as it may be made of carbon. Others and me are having the same problem but I haven't found the proper replacement
Sorry for the dust on my pictures
#8 Posted : 12 June 2018 15:17:23(UTC)
Thanks Jean! I will be giving it a try soon.
#9 Posted : 13 June 2018 02:55:27(UTC)
Update: I managed to open the shell. It was on very tight and the plastic seems to have lost its elasticity, so it did split a bit at the back.
I was able to rotate the two wheels for the jib and hook lines enough to release the tension and it is now working again! Phew!
thanks!
This page was generated in 0.414 seconds.
