Offline Michael4
#1 Posted : 30 June 2017 16:23:31(UTC)
Michael4
7011 is the code for catenary masts that fit metal bridges. They have a tongue that slides into a slot in the bridge and the mast on an adjustable slide. These days they would appear to be seriously expensive, well the few I can find are.
Has anyone made a substitute? I'd like to keep my metal bridges, after all the rust effect on them is genuine rust!
Offline BenP
#2 Posted : 02 May 2023 02:18:19(UTC)
BenP
Same here. Hard to find masts + holders for vintage metal bridges. What's an alternative construction (or brand)?
Ben
Update: Saw this clever solution, turning 7009 base around and trim end hook. Looks like one could do this even nicer with thin metal strip.
thanks 6 users liked this useful post by BenP
Offline BenP
#3 Posted : 24 May 2023 19:35:54(UTC)
BenP
I decided to create my own 7011 mast, using thin sheets of metal (from window blind) with a drilled hole for old style mast crews. I removed the original bottom stand of a mast and replaced with metal strip. I use double strip to create more grip. Catenary lengths match the separation of ramp slits, so no need for adjustable positioning.
thanks 2 users liked this useful post by BenP
This page was generated in 0.209 seconds.
