Offline Moritz-BR365
#1 Posted : 28 June 2017 15:05:41(UTC)
Moritz-BR365
I bought this cute Brawa KLv 60.9001 Catenary Test Coach some weeks ago.
The original version from Brawa is analog AC, but this one had already a C90 digital decoder. But the driving performance wasn't so good, a bit loud and the rear lights are always changing with the front head lights. I decided to insert a mSD sound decoder and change the lights, to be able to switch off the rear lights.
First, remove the old decoder and all cable to the big circuit board:
Then, I made two small cuts into the conducting path, to solder later the AUX1/AUX2 to the rear lights.
I marked the cutouts with red circles, the yellow points are the solder points for the head lights, the red dots those for the rear lights:
For test drive, I sticked the speaker on top of the decoder:
After test drive, the speaker found a place under the roof:
And this is, how it looks and sounds:
The driving performance is much better with the mSD decoder, fabulous slow driving, very silent motor!
What is to do:
  • Better sound project
  • change lights from bulb to LED
#2 Posted : 29 June 2017 20:27:01(UTC)
Moritz-BR365
New soundproject of the VT 75.9:
#3 Posted : 09 August 2017 15:30:29(UTC)
Moritz-BR365
The model contains a head signal light on both sides. Brawa didn't realize this. Therefore, I bought cast brass headlights from Weinert.
This headlights are not designed to be equipped with a SMD LED. Therefore, I had to mill the headlight interior and drill a 0.6mm hole for the wires:
Hole from outside...
and inside:
The drill:
1st head light is ready:
1st test assembly:
And here the second one, even better:
thanks 2 users liked this useful post by Moritz-BR365
#4 Posted : 13 August 2017 00:36:43(UTC)
Moritz-BR365
And the final show, all headlights and rear lights with LED:
This page was generated in 0.386 seconds.
