Offline corywendorf@mac.com
#1 Posted : 18 June 2017 17:21:57(UTC)
corywendorf@mac.com
Hi everyone,
I've returned to the hobby after 35 years and have started with the 29000 starter set and a few of the "C" track additions.
Everything was running fine but I had an issue with the train cars derailing on a yard switch. I went to pick up the car and there were some sparks as i did this. \
Now my MS2 is frozen with the loco name on the screen and the "stop" buttons are illuminated - pushing either "stop" button yields no response. The shift keys work but that is about it.
I've tried the MS2 with a separate section of track apart from the main layout - same result. All wires are correct
Is there anyway do to a reboot on the MS2 or am I screwed at this point?
Any help / suggestions would be greatly appreciated
Cory
#2 Posted : 19 June 2017 07:53:29(UTC)
Hi, Cory,
Welcome to the forum.
Reboot: pull the wallwart out of the wall, count to ten, plug it in again.
There is a factory reset in the menu (available only when the menus are working). That should not be required.
A third option: plug the MS2 into a CS2 while pressing the speed knob. That should not be necessary and you will have to meet someone with a CS2 to try this.
#3 Posted : 19 June 2017 10:20:21(UTC)
Just to clarify
The MS2 (60657) is the hand held device
- this plugs into a
TrackBox (6011x) - the 29000 set comes with the black 60116
- that receives the power from the
Power Supply (66360/1/5/7)
The symptom you describe sounds familiar (a while back now) of a TrackBox issue - anecdotally linked with a failed firmware update.
I do suggest you try and find another MS2 user (with their Track box) or a CS user, and verify your MS2 works there.
If it is a TrackBox issue, I believe returning to Marklin is the only option.
As a comment,
One thing to do is check that the pins in the plug/socket have not been damaged
#4 Posted : 19 June 2017 18:24:13(UTC)
corywendorf@mac.com
Hi, Cory,
Much appreciated - took the MS2 down to West End Trains in Mississauga. Mike tried to get it it to work with their CS2 and on its own - no luck - unit was locked up. Mike exchanged it with new MS2 under warranty.
thanks 1 user liked this useful post by corywendorf@mac.com
#5 Posted : 19 June 2017 18:25:44(UTC)
corywendorf@mac.com
Just to clarify
- this plugs into a
As a comment,
#6 Posted : 19 June 2017 21:50:21(UTC)
So the question now remains, what about that derail short cause this issue, as there is circuitry in the track box and MS that should prevent damage from a short.
Any insight from a visit to the train shop on what may have happened?
#7 Posted : 20 June 2017 02:41:40(UTC)
corywendorf@mac.com
They were just as stumped as I was. I was told both the railbox and the MS2 have circuitry that will reset in the event of a short. The only explanation is a faulty MS2. I plugged in the replacement MS2 when I got in from work, it immediately recognized the MFX signal from the loco and everything ran without issue. I did a run through my two mainlines and the yard - all switches worked - everything ran fine.
Offline PauloM
#8 Posted : 17 March 2021 23:12:58(UTC)
PauloM
Hi, Cory,
Will the third option work with a CS3+: my MS2 is frozen too!Thanks
#9 Posted : 18 March 2021 10:24:43(UTC)
Never tried it with a CS3, but worth a try.
Since you press a button on the MS2 to trigger a special mode, I hope the trick will work with both CS2 and CS3.
Offline 3rail4life
#10 Posted : 24 July 2021 02:50:02(UTC)
3rail4life
Hello Tom,
Your third option has saved a couple of MS2's that were bricked during updates, thanks for sharing it. Today when I tried it with my CS3, it did not work. Not wanting to push my luck I took it to the CS2 were it worked fine and fixed the MS2.
Gordon
Guest (11)
This page was generated in 0.324 seconds.
