Offline DV
#1 Posted : 11 June 2017 10:35:34(UTC)
DV
A friend has asked me to try to do the latest upgrade for CS2 through the internet as he was having problems. He wasn't to sure whether his internet connection was in good working order as he couldn't even get onto this forum.
I plugged it into the modem, clicked upgrade internet and got this message:-
/usr/bin/dbclient:exited:Error resolving: Temporary failure in name resolution
rsync:connection unexpectedly closed (0 bytes received so far) [receiver]
rsync error:error in rsync protocol data stream (code 12) at io.c(453)[receiver=2.6.9]
What I understand is that it is refusing to download the latest upgrade.
Why? Well it can't be with the internet connection (mine works perfectly)
Could it be that something is 'gummed' up in the CS2?
The controller works fine, it registers and runs locos.
Just won't upgrade.
The only solutions I can think of is to reset to factory conditions, thereby loosing all registered locos and any other info and then trying to upgrade hoping it would work
Or trying with a 'stick', but if you can't upgrade with internet connection, I'm confident the stick won't work.
Any help would be greatly appreciated.
Dusan V
#2 Posted : 11 June 2017 11:10:11(UTC)
No, this is just a basic "unable to FIND a PATH to an update to be downloaded."
While the update server may occasionally be unavailable ..
.I would check that it is not YOUR end and either the CS itself or your local router is not able to do DNS resolution.
please ensure
- you do have Your dhcp ENABLE so that a gateway path can be found,
- (or ensure it is FULLY set up manually)
- your router is functioning properly (i.e. that it can find/use a DNS)
#3 Posted : 11 June 2017 11:18:07(UTC)
I check update on CS2 and 'The update is Complete'. It work fine.
Software update to date 4.1.2(3).
#4 Posted : 11 June 2017 11:55:40(UTC)
......he couldn't even get onto this forum.
There's your problem. As Clapcott says, you have a DNS or name resolution issue - website names cannot be resolved to tcpip addresses.
Your router should be pointing to at least 2 external DNS servers, hopefully your ISP should specify some, if not you can use Google's public DNS servers on 8.8.8.8 and 8.8.4.4
Offline franciscohg
#5 Posted : 11 June 2017 16:02:35(UTC)
franciscohg
Chile
While you solve the router configuration, have you tried the USB update?
#6 Posted : 11 June 2017 16:15:47(UTC)
Did you check if yours PC do stand IPv4 and DHCP automatic?
It configure yours CS2 automatic and when you download new upgrades.
A problem is with wireless wifi router while switch port is more safety.
Offline DV
#7 Posted : 18 June 2017 07:09:02(UTC)
DV
Thanks to Peter's spot on advice, problem is now solved and CS2 is updated to latest version......woohooThumpUp ThumpUp ThumpUp ThumpUp
Many thanks Peter
Dusan V
thanks 1 user liked this useful post by DV
This page was generated in 0.546 seconds.
