Offline drnodk
#1 Posted : 30 May 2017 04:20:30(UTC)
drnodk
Can't figure out how to connect my cs2 to my new cs3
#2 Posted : 30 May 2017 04:40:00(UTC)
Check the CS3 manual, details are there. You need an additional cable.
https://www.rocousa.com/.../manual_cs3_en_12.16.pdf
Offline franciscohg
#3 Posted : 30 May 2017 04:59:57(UTC)
franciscohg
Chile
You need a 60125 to do it
#4 Posted : 30 May 2017 05:07:31(UTC)
You also need a 60123 connecting cable.
Offline franciscohg
#5 Posted : 30 May 2017 05:08:56(UTC)
franciscohg
Chile
Friendly M hardware LOL
#6 Posted : 30 May 2017 05:52:34(UTC)
No, you do not "need a 60125".
Multiple "Terminals" (60125/60145), "2m Extension cables" (60126) and CS3+ (60216) MAY be included in the bus connection from a CS3 (60226) to a CS2(60213/4/5) - up to 100m
However the minimum requirement, using the system bus, is one 60123.
Comment:
Marklin document limitations in the USE of a CS3 (60226) and/or CS2 (60213 = actually HW v 3).
This pertains to the track side isolation not the system bus device connections.
Ref: table at bottom pf pg 31 ...
https://www.maerklin.de/...rklin_Digital_MM_1_2.pdf
So before you ask "how do I connect .." the real question is "can I connect" followed by "what are the limitations"
1- If your CS2 is not HW v3 or your CS3 is not a 60226 then they may be connected in both system bus and track (with usual track isolation)
2- If your CS2 IS HW v3 AND your CS3 IS a 60226, then they may be connected for common control (system bus) but should not be used to run trains between their track power sections.
3- If using a PC/Ethernet and not the system bus for connection - then the same limitations for the track connection as with -2 apply.
Edited by user 30 May 2017 11:05:20(UTC)  | Reason: Not specified
Guest (5)
This page was generated in 0.277 seconds.
